Old 07-25-2010, 11:25 PM   #1
Newberry , Florida
Sheets for the '73 Overlander?
Need sheets. The foam mattresses are measuring 32" x 75" x 6". Any place I can buy a few sheet sets without the installment plan?
Overlander is offline   Reply With Quote
Old 07-26-2010, 01:03 AM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Sheets on the cheap!
Both Wal*Mart and Target sell twin XL sheet sets which might work for you. My twins have the radius corners and we are adapting some of these to fit. I replaced the 43 year old foam mattresses with inner spring ones from newer model A/S trailers. It was a lot of work to re-size the shorter one by the entrance door but well worth it for the added comfort. Also foam tends to make me sweat! So all the sheets we will use will be "off the shelf" until we see how we like them. In the future we may get some of the more expensive ones from A/S but for now we will make do. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-26-2010, 06:15 AM   #3
Rawfoodgirl3's Avatar
1973 23' Safari
Bethlehem , Pennsylvania
Images: 16
I just used regular twin sized fitted and flat sheets and tucked them in on our '73 Safari (same size foam as yours I think). They fit fine. The comforter is pictured.
Ellen
Rawfoodgirl3 is offline   Reply With Quote
Old 07-26-2010, 06:28 AM   #4
funkill's Avatar
reno , NV
Images: 27
I use Target's knitted Twin size for my larger-than-twin bed at home and on my (not-so-double double in the Overlander.
Using flat twin size is another good idea!
Laura
funkill is offline   Reply With Quote
Old 07-26-2010, 10:17 PM   #5
Newberry , Florida
Think I might try these (34x75). I know there a bit wider, but should allow for a down or memory foam pad.
Amazon.com: Camper Bunk 34x75 Percale Sheet Set White with Azure Blue Trim: Kitchen & Dining
Beds & Sheets iHayley General Interior Topics 57 07-08-2012 10:27 PM
Sheets TLMILLER 2007 Safari SE 4 07-19-2007 12:12 PM
Sheets SETSAIL General Interior Topics 10 03-18-2007 02:53 PM
Got Sheets????? iowaroots Commercial Listings 2 06-06-2004 02:05 AM
Sheets that FIT!! dtbw 1997 - 2004 Bambi 8 09-10-2003 09:29 AM
