Old 04-12-2004, 05:58 AM   #1
dreamin's Avatar
Salisbury , Maryland
Question Shades won't stay up
Hi All! First post....I've read a lot, thx for your help so far.
We just got our 2003 Classic, used from a dealer. Everything looks great, but the shades on the front window won't stay up. These are the widest ones, which may have sg to do with it.
Is there a way to adjust the tension?
Thanks.
dreamin is offline   Reply With Quote
Old 04-12-2004, 10:12 AM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Loosen the screws at the bottom of the strings on each side and tighten the strings, then retighten the screws. The strings must be kept quite tight to keep the blinds from sliding down.
John W. Irwin
WBCCI #9632
Old 04-12-2004, 01:40 PM   #3
I have just wound the bottom of the string around the bottom button with good results. I don't like loosening and tightening screws unless it's necessary cuz after a few times the hole will become loose and need a wooden match stuffed into it...
Elliott B
ElliottBartlett is offline   Reply With Quote
Old 04-12-2004, 02:19 PM   #4
Pahaska's Avatar
Hays County , Texas
I don't usually find enough slack to wind the string around. The string doesn't have to be very loose for the shade to slide down.
John W. Irwin
WBCCI #9632
Old 04-12-2004, 03:54 PM   #5
stuart2's Avatar
I don't know how your shades are built but the same thing was happening to my shades and to fix that problem I made a strap that has one end permanently connected to the back side of the frame of the shade and attached a fastener off of an old worn out pair of bib overalls to the other end of the strap. When I want the shade to stay up I pull the shade to the full up position and then wrap the strap under neath it and hook the bib fastener onto a hook on the front side.
I hope that made sense, a picture's better than 1K words, unfortunately the MH's not near by to snap a pic. Good luck. Stuart
stuart2 is offline   Reply With Quote
Old 04-19-2004, 05:58 AM   #6
dreamin's Avatar
Thanks a lot, guys! I just wound them for now...works great.....I'm sure I will need to loosen the screws eventually.
Angels Camp, CA area... where to stay? Safari Tim On The Road... 1 08-20-2003 03:42 PM
Backup Lights Stay On (Help!) pscottn Lights - Interior & Exterior 4 08-18-2003 11:59 AM
Pleated Shades for a 1999 Safari JaceBeck Upholstery, Blinds, Walls & Interior Finishes 1 02-17-2003 09:42 AM
Looking for new shades... larrylisa Upholstery, Blinds, Walls & Interior Finishes 7 12-05-2002 08:25 AM
