Old 09-12-2008, 12:59 PM   #1
2011 27' FB Flying Cloud
Bradenton and Saluda , Florida & North Carolina
Safari Front Window Curtains
Hi all, have a ?? knew someone out there would know the answer. I am making new curtains for the Safari and noticed the factory curtains are cut at an angle and there is a difference between top and bottom also. If I make them straight, will I have a problem. Also using the elastic, plastic hooks for the track, can I sew them at regular intervals rather than the wierd measurements that airstream used?
Thanks in advance for your help!
Nan
ncbambi is offline   Reply With Quote
Old 09-12-2008, 01:35 PM   #2
starflyte1's Avatar
2007 25' Safari FB SE
Lady Lake , Florida
Nan, this is not an answer to your question, but may be something to think about. Someone on this forum used the original curtains as a liner and just sewed new fabric on top of the original. That way you could use the original curtain slides. Good luck! Pat
Pat
AIR# 16756
WBCCI# 6167
starflyte1 is offline   Reply With Quote
Old 09-12-2008, 01:37 PM   #3
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Originally Posted by ncbambi View Post
Hi all, have a ?? knew someone out there would know the answer. I am making new curtains for the Safari and noticed the factory curtains are cut at an angle and there is a difference between top and bottom also. Nan
Yes, they are cut at that funny angle for a reason. There isn't a straight line in reality from bottom rail to top. Use your old curtains as your pattern and you will be fine!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 09-12-2008, 04:53 PM   #4
Thanks for the info. Kind of thought that was the case. The suggestion of sewing right on top of the old ones is a great idea, that way they would also be more of a blackout type curtain.
Old 09-13-2008, 02:33 AM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Nan...You're right...the curtains are not true rectangles and there is an art in getting the track curtain glides in the right places so that when the curtains are folded they look good and fold correctly...the windows are shorter across the top than they are across the bottom...they are a trapezoid shape. Greg makes curtains for newer Airstreams...you should be OK if you use the old curtains as patterns or guides, or even sew right onto them (unless you want to keep the originals for resale or whatever)... However, we now make 2 long panels rather than 4 short panels because they are easier to manage... We line all our curtains so they are more substantial than those AS provides... PM us if you need his input...and/or check our website below...
TB & Greg and Abbey Schnauzer
#3954
Old 09-13-2008, 07:39 AM   #6
TB - thanks for the info. Kind of figured it was for that reason, but my "maybe it could be sewn differently" set in. The old pattern it is!
Front Curtains INSPECTOR Member Introductions 2 11-22-2007 10:03 PM
'64 Safari front & rear window achip Windows & Screens 2 09-06-2006 09:43 AM
Size of Front Window 19 safari Bambi? glacierrunne 1997 - 2004 Bambi 3 05-13-2005 07:07 AM
Repairing Front window '63 Safari srgntpepper Windows & Screens 10 08-29-2003 08:27 PM
Leaking Front Window '63 Safari srgntpepper Windows & Screens 1 08-16-2003 04:25 PM
