Old 02-22-2009, 05:53 PM   #1
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
Room Darkening Shades
Has anyone installed room darkening shades in their Airstream? Thanks
willyd is offline   Reply With Quote
Old 02-22-2009, 07:25 PM   #2
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Yes, I put day/nite shades in my trailer. They are pleated blinds and when you pull the first section down, it blocks vision, but lets light in, pull down the second section and it blocks the light. Love 'em!
So Long!
Bob Thompson is offline   Reply With Quote
Old 02-22-2009, 08:04 PM   #3
LLB21's Avatar
You can even have your drapes made with black-out lining. Then all the corners are covered.
Louie
LLB21 is offline   Reply With Quote
Old 02-22-2009, 09:23 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We use the insulated silver reflective material from Lowe's between the windows and the curtains. We bought the material by the roll and cut it to size for each window. It works grate and costs very little. The liners on the bedroom windows have not been removed in over two years. It keeps the bedroom dark so that we can sleep past dawn. It also significantly helps with the A/C and heat. It also does an excellent job of eliminating sun fade during storage. We also made panels of this material for the skylight and the Fantastic Fans.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 02-22-2009, 10:56 PM   #5
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Hey Bob, where'd you get them?
Safari64 is offline   Reply With Quote
Old 02-23-2009, 02:38 AM   #6
imeynstein's Avatar
Texarkana , Arkansas
Hey, if you do your own curtains and want a very cost effective way to block the light, I found black panels at the dollar store. You can either put pleats in them and use them as your curtains, or just cut a panel to fit over your windows...They work great, but I am still wanting to place the silver tinting on my windows to match the exterior of my AS....Our Lowe's does not carry this tint...Does anyone else know of a place where I can get this? I even tried at our local Auto Zone, but they only had a silver that faded to a black tint....
imeynstein
imeynstein is offline   Reply With Quote
Old 02-23-2009, 06:45 AM   #7
willyd's Avatar
1993 34' Limited
Thanks for all your ideas.
Old 02-23-2009, 10:31 AM   #8
Images: 67
I bought mine at an RV supply store in Quartzsite, but you can pick them up off Ebay for about the same price. I had to buy mine long then cut them to length which was tedious but it worked. I would determine the width needed to fit the window then I would disassemble the blind, use a razor knive to cut the length and a hole punch to make new holes for the string. I also had to use a hack saw to shorten the aluminum bars at the top and bottom. I worked carefully and did not rush, they turned out looking like factory. If you plan to do it, be sure to either make a diagram showing the stringing technique or have a second one to help guide the stringing.
So Long!
Old 02-23-2009, 12:40 PM   #9
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Brian
Brian, do you have any photos? How do you hold them in place? Sounds goodócombines darkness and insulation.
Gene
Old 02-23-2009, 03:43 PM   #10
Cincinnati , Ohio
Gene
Gene,
I did the same thing in my AS. It is time consuming, but not difficult.
I measured the size of the opening, and made the foil bubble about a 1/4" larger. Cutting the radiuses was the hard part, and required lots of test fitting. When it is just right, push it in place and it will stay there without any help. The bigger windows might need a bit of aluminum tape to help them stay put, just don't get the tape on any paint. It'll all be hidden behind the curtains anyway, so there's no need to worry too much about appearances.
Hope this helps,
Woody
Woody.303 is offline   Reply With Quote
Blinds/Shades nilesrob Upholstery, Blinds, Walls & Interior Finishes 22 08-02-2007 05:02 PM
B-van shades Paul NC Upholstery, Blinds, Walls & Interior Finishes 0 11-18-2006 08:31 PM
cleaning shades aeriqua Upholstery, Blinds, Walls & Interior Finishes 4 04-23-2006 12:10 AM
Shades won't stay up dreamin Upholstery, Blinds, Walls & Interior Finishes 5 04-19-2004 05:58 AM
Looking for new shades... larrylisa Upholstery, Blinds, Walls & Interior Finishes 7 12-05-2002 08:25 AM
