Old 11-26-2007, 09:15 PM   #1
1974 29' Ambassador
1971 31' Sovereign
Klickitat , Washington
Roller shade in 1974 Ambassador
Hi folks, there's a roller shade over my sink. It is inset into a "box", which has side indentations for securing the shade at different lengths. It needs to be adjusted, as it no longer rolls up properly. But I can't figure out how to remove the roller to do this, and the mounting hardware is different from the hardware I've been used to all my life. Anyone know how to do this?
jacqueg is offline   Reply With Quote
Old 11-26-2007, 09:18 PM   #2
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
Hi and Welcome. Can you post a picture and Im sure we can figure it out.
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 11-26-2007, 10:59 PM   #3
The galley window shade has the same mounting brackets as do many homes.
One bracket has a round hole in it. The other bracket has a vertical slot. One end of the shade has a round shaft and the other end of the shade has a flat shaft.
You can feel which end is which by holding the shade in the middle, and gently shaking it upward as you ever so slightly rotate the shade.
When the flat blade is absolutely vertical in it's bracket, that end of the shade will simply lift up.
There is not much room to work with, so be patient and gentle, and all of a sudden the shade will lift up on one end.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-27-2007, 01:42 AM   #4
1974 29' Ambassador
1971 31' Sovereign
Thanks Andy, that worked. You are sure right about the lack of working room! Since I have to fix it anyway, I might cobble up a roman shade instead, and save myself barked knuckles in the future.
Old 11-27-2007, 07:03 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Be real careful not to put undue pressure on the plastic frame where the mounting brackets are. Likely it has become brittle over the years and will easily break.
Old 11-27-2007, 07:35 PM   #6
A/SimpleLife's Avatar
1971 29' Ambassador
Sunny South , Florida
And once it cracks, then how do you cover that window?! I've been trying to figure that out, because mine is very, very brittle. I like Sergei's idea of the spray on "frost" he did in his Argosy.
Gwen
A/SimpleLife is offline   Reply With Quote
Old 11-27-2007, 09:25 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
I have exactly that problem. I plan to take the window trim off and patch it from the rear with fiberglass. It's on my to do list. There is the risk that removing the brittle trim will cause more cracks though, especially at the rivet holes.
Old 11-28-2007, 07:30 AM   #8
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
window trim
Lumatic and Gwen, Have either of you tried the factory parts department at Jackson Center. They might still carry this trim part in stock? I was to understand that they carry a lot of parts for older A/S models back to 1969. Let us know what you find out. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 11-28-2007, 12:23 PM   #9
St Louis , Missouri
75th anniversary interiors
Don't know how to post a picture but ifyou go to Vintagetrailer.com it has it on the second page under 75th anniversay.
slimitch is offline   Reply With Quote
Old 11-28-2007, 02:47 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
I did not see anything called 75th anniversary at this address
Old 11-29-2007, 03:51 PM   #11
1974 29' Ambassador
1971 31' Sovereign
Oh dear, not another fixit! I checked mine, and it doesn't appear to be brittle. Thought about removing it altogether, but it is screwed, riveted, and caulked. Don't want to mess with that either, I'm living in my A/S now, and it's definitely winter here.
Think I'll just get a tension rod, and put up an insulated curtain.
Old 11-29-2007, 06:28 PM   #12
2000 25' Excella
That sounds like the best quick fix. I removed mine in the 72 we had and made a curtain with rod pockets at the top and bottom. John riveted the top rod in place. on the bottom i used the hardware and placed it upside down to make it tight. That helps to keep it back so it doesnt get wet or hang to close to the stove. I will see if I can find the picture if it sounds like something you might want to consider.
John & Tammy Adams
Old 11-29-2007, 06:47 PM   #13
1974 29' Ambassador
1971 31' Sovereign
Yes, indeed I would like to see what you did! Thanks.
(one of my favorite things to do at this forum is look at the mods people have done to their units.)
Best way to hold roller shades bgarrison Upholstery, Blinds, Walls & Interior Finishes 8 04-07-2009 05:57 PM
control panel removal? 1974 Ambassador jacqueg Electronics & Connectivity 4 11-29-2007 04:16 PM
1974 Ambassador 29' airboy1 1974 - 1979 Ambassador 1 08-13-2006 08:26 PM
? carter shade awning roller tube retro-active-couple Awnings 3 06-23-2004 03:56 PM
