Old 06-25-2014, 11:09 PM   #1
cmmorsey's Avatar
2008 23' International
carlsbad , California
Rivets missing on inside wall
Name:	ImageUploadedByAirstream Forums1403759327.890800.jpg
I think the pic says it all. How do I replace/fix?
Thanks!
Airstream 2008 Int Sig 23d
2012 Ford F150 FX4
cmmorsey is offline   Reply With Quote
Old 06-25-2014, 11:36 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Rivet gun and ALL aluminum Pop Rivets.
Best guess is 1/8" but could be 5/32".
Old 06-25-2014, 11:39 PM   #3
cmmorsey's Avatar
TG T... It's 2008... Not sure if there is way to know for sure?
2012 Ford F150 FX4
Old 06-25-2014, 11:53 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
All big box stores carry pop rivets. Buy a box of 25 of each size. And see which one fits in the hole. Get a quality pop rivet gun.
Be sure to get ALL aluminum rivets.
If you keep having rivets pop and they are 1/8". You may eventually have to increase the size to 5/32" to compensate for the continual drilling and enlargement of the hole.
Some will say pop rivets breaking is caused by vibration from the running gear being out of balance. Which could be the case.
Other causes may be a sudden shock of hitting a pot hole or curb etc.
Or the aluminum sheet not being properly installed at the factory. Lose installation to begin with, allowing the rivet to move in the hole and get cut off.
Or simply a weak pop rivet.
Old 06-26-2014, 07:32 AM   #5
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
When rivets start to pop, they are often a symptom of greater ills. As mentioned above, it could be caused by wheels out of balance, etc., but it could also be a broken frame, hardened elastomer rods in your axle, too stiff of weight distribution bars, too burly of a tow vehicle, etc.. Take a few minutes to slide underneath your trailer and have a good look around. Also take a good look at the exterior of your shell, and look for buckling/bowing panels, rivet damage, cracking, etc.
good luck!
Old 06-26-2014, 07:48 AM   #6
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Put an aluminum rivet in. I had one missing on my roof. You may need to borrow a shaver for the rivet.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-26-2014, 08:37 AM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Interior rivets are pop rivets that do not need to be "shaved." You're thinking of an olympic rivet that is often used to replace a popped buck rivet on the exterior skin. Olympic rivets need to be shaved to look like a normal buck rivet.
In any event, before inserting the replacement pop rivet, make sure to carefully drill out any remaining metal from the old rivet. And by careful, I mean to make sure you don't pierce the exterior skin of your trailer!
Bob Martel
WBCCI# 5766
Old 11-09-2014, 02:20 PM   #8
1989 25' Excella
What size drill bit best used to remove 1/8 inch pop rivet?
PAL07 is offline   Reply With Quote
Old 11-09-2014, 02:27 PM   #9
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
1/16" should do.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 11-09-2014, 02:36 PM   #10
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Originally Posted by cmmorsey View Post
Attachment 214938
Thanks!
2012 Ford F150 FX4
Don't buy the rivets at the "Big Box Store", as they are likely aluminum rivets with a steel mandrel. We see this all the time, they are a real pain to drill out the steel mandrel, plus the mandrels tend to rust & leave stains on the interior. I get my pop rivets through Fastenal & make sure they are aluminum rivets with an aluminum mandrel. I believe Vintage Trailer Supply also carry's them. They are 1/8" diameter.
Colin
Colin H is offline   Reply With Quote
Old 12-18-2014, 06:39 AM   #11
1995 34' Limited
1978 23' Safari
Napanee , Ontario
rivet length
The internal rivet size is 1/8", what would be a typical length of rivet for internal skin installation?
Bas&Wen is offline   Reply With Quote
Old 12-18-2014, 01:39 PM   #12
1981 31' Excella II
New Market , Alabama
1/8" long all aluminum pop rivets are fine but 1/4" long will work fine as well. A few broken rivets it common even on newer trailers. Now when you have several along the same rivet line then you may have to vibration issues. Rivets tend to loosen up close to the wheel wells, since that is where most of the vibrations are from out of balance tires or worn out axles that no long have any spring left in them.
Perry
Old 12-18-2014, 01:55 PM   #13
ottawa (greely) , Ontario
When we bought our first airstream(2012) we were told at the dealer there maybe a few rivets that might pop out on our way home . And when we got home sure enough there was one and after a few months another popped out , when we were in jackson center getting all our warrantee work done ,they replace the two rivets with stainless steel rivets and told us this is what they do . This is what the tech told us ,he was instructed to replace any aluminum rivets that pop out with stainless steel rivets. Hope this doesn't cause any corrossion problems ( two dissimilar metals cause corrossion this is what I know from the automotive trade) I guess I will never know as I sold it last summer.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 12-18-2014, 02:19 PM   #14
Mike91208's Avatar
2009 27' FB International
LA LA Land... , California
This happens to me, occasionally, and I just wait until I have the trailer serviced at an Airstream dealer. Last time they charged me all of $0.75 per rivet.
Mike91208 is offline   Reply With Quote
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Missing Rivets on inside of door rperrym Windows, Doors, Locks & Vents 7 11-30-2010 07:48 PM
Missing Exterior Rivets carls017 Ribs, Skins & Rivets 5 10-13-2003 08:55 AM
