Old 09-19-2016, 01:46 AM   #15
1978 31' Sovereign
Gig Harbor , Washington
I know your post about removing your inner skins was in 2007, but I'm running into a similar problem with my trailer I just bought (1978 31 Sovereign). Someone tried to redo the walls before me by just skinning over the old walls so I have 2 skins to remove. I'm guessing the frame is going to look like swiss cheese. Do you have a reliable source to get 2024 aluminum and what were your pointers?
Tim Sypowicz
TSypowicz is offline   Reply With Quote
Old 09-22-2016, 02:07 PM   #16
Cragnomad's Avatar
1976 Argosy 24
SLC , Utah
Andy, what do you mean about removing interior metal? I can remove the interior skins without bracing anything, right?
Cragnomad is offline   Reply With Quote
Old 10-24-2016, 12:55 PM   #17
Nashville , Tennessee
Did you ever figure this out? We have a 1955 22' Flying Cloud and we took out the walls to replace insulation, but want to build out interior with a different material so paint white for a mobile store. Not sure what to use bc I don't want to use shiplapp.
krdrift is offline   Reply With Quote
Old 04-21-2017, 10:48 PM   #18
Gatineau , Quebec
Removing, cleaning, reinstalling and painting the inside skin
I am getting ready to renovate (gut completely) an 18 feet Travelux. There has been lots of water damage and beleive that I may as well do it right. I am wondering if I can remove the inside skin, take of the vinyl, reinstall the panels and paint it a nice clean white. Any views on this?
Also, I am not sure where to start... should I repair the outside first and then the inside. There is a lot of water infiltration, the belly pan has to be replaced (at least partially) and I am not sure what the frame looks like. As I pulled the dinette out, the floor caved in... That part of the frame is rusted.
Looking forward to learn from your expertise.
Though it is not an airstream, it is a closed cousin..
Julie
Juliec is offline   Reply With Quote
Old 06-14-2017, 05:15 PM   #19
Pleasant Plains , Arkansas
Originally Posted by HeikeET View Post
I just stuck sticking metal tiles all over interior walls. No prepping was needed on mine. I just pulled off the carpet and replaced it with the tiles .. Looks amazing Attachment 271282
That's looks AWESOME! If you don't mind sharing, where did you find the tiles?
go_lope is offline   Reply With Quote
Old 06-14-2017, 06:52 PM   #20
1979 23' Safari
Wayland , New York
Julie
Julie,
I would take out the interior skins first. This will give you access to the inside of the exterior skins for repairs, sealing, riveting, etc.
Keep the interior skins someplace safe. Strip them and prime them before reinstalling them. If you get them down to bare metal I would recommend priming them with self etching automotive spray primer.
If you're really handy and can afford a little bit you could even consider replacing the interior skins with new metal. Since it's 18' trailer a 12'sheet would brobably span end to end before the curves. This is definitely more feasible if you're near a big city.
Joe
Leak at rear bedroom wall Kirby Stone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 02-12-2010 11:41 AM
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
Replacing Skins NSMITH Ribs, Skins & Rivets 8 06-04-2002 03:02 PM
