Old 06-30-2009, 03:21 PM   #1
DPM
1973 Argosy 20
fayetteville , West Virginia
Replacing Vinyl Walls on 73' Argosy
My wife thinks I am a nut because I have been lurking airforums and other sites for months, and my curiosity of vintage trailers quickly turned into an obsession. We own a rock climbing publication www.deadpointmag.com and I decided that a vintage trailer badged out in our magazine's logo was a marketing necessity. I loved the airstream design, but painting one would be a crime, so the Argosy naturally became my trailer choice.
This morning at 4am, my wife and I arrived home with our new restoration project. We purchased Steve Fixx's 73' Argosy http://stephenfixx.blogspot.com/ , and we have big plans for her.
At 8:30 am I woke up struggling from a lack of sleep. After slamming a pot of coffee to clear the cobwebs, we began gutting her interior. We know she has several leaks, and feel the interior vinyl walls will need to be removed in order to find the leaks and repair them. The old vinyl walls are held in with rivets and have several old rivet holes. We are looking to create a very clean finish to the walls, and the old vinyl isn't going to cut it. My question is, where do we find the suitable replacement vinyl? And, are there cleaner options than rivets?
DPM is offline   Reply With Quote
Old 06-30-2009, 03:26 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
The vinyl walls (at least the ones on the exterior walls) are actually aluminum coated with that vinyl. Getting it off the aluminum may be a serious chore. Do some research before you undertake this. I might consider painting them......
Congrats on the purchase and finally de-lurking
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 07-01-2009, 08:38 AM   #3
DPM
1973 Argosy 20
I am referring to the vinyl sheeting that make up the interior. The exterior is the painted galvanized steel.
Old 07-01-2009, 10:33 AM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by DPM View Post
I am referring to the vinyl sheeting that make up the interior. ...
So is Janet.
Vaughan
Old 07-01-2009, 10:40 AM   #5
Janet H's Avatar
1964 26' Overlander
Images: 90
Your trailer has an exterior skin and an interior skin. In between there are aluminum ribs (sort of like studs). The interior skins are usually vinyl clad. The exterior skins are aluminum except for the end caps which are galvanized steel. If you are unsure which part of the exterior is steel - use a magnet to check it out. It won't stick to aluminum.
Old 07-01-2009, 11:03 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
And both the interior skin and exterior skin work together to create an integral structure for stiffness. Removing interior skins during restoration is common but you have to put them or an exact copy back in place.
5 meter Langford Nahanni
Old 07-01-2009, 07:17 PM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I had the same problem with my 1972 Sovereign. My walls were stained, had ugly paint and had numerous holes in them. My solution was to cover the interior walls with Ozite Rib Fabric (aka Hull-liner). It looks great and adds another layer of insulation. Oh yeah, I almost forgot to mention that most of the newer Airstreams have Ozite Fabric on the walls. See my blog for more details.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-01-2009, 09:35 PM   #8
DPM
1973 Argosy 20
Thanks everyone. Im glad to hear I don't have to remove the interior walls. I've started sealing the exterior and the interior is gutted except for the fridge. I found an mouse nest in the bathroom fixtures I removed today. Removing the shower and dark water tank only confirmed that we will have to redo the floors. The worse it looks, the more excited I get about the restoration process. This is going to be an awesome experience. I can't wait to share a beer and give my first tour when she is done.
Stripping interior vinyl covered walls Anna Upholstery, Blinds, Walls & Interior Finishes 87 10-12-2014 03:39 PM
73' Argosy Waste Tank Sundance Waste Systems, Tanks & Totes 12 07-22-2008 06:17 AM
Stripping only down to vinyl on walls Excella71 Upholstery, Blinds, Walls & Interior Finishes 6 11-26-2007 05:38 PM
a good cleaner for vinyl walls zoeb nj Upholstery, Blinds, Walls & Interior Finishes 22 05-06-2007 06:12 PM
vinyl covered walls dustyrhodes General Interior Topics 7 10-04-2005 06:09 PM
