Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 08-17-2014, 11:15 AM   #1
1986 25' Sovereign
Cincinnati , Ohio
Replacing ABS plastic walls in vintage trailer
We are looking at a 1986 sovereign. The walls and ceiling appear to be paneled in ABS plastic. We wonder if there's an aluminum skin beneath the ABS or if the ABS serves as the inner skin. If so, can ABS be painted or replaced?
Ssmookler is offline   Reply With Quote
Old 08-17-2014, 12:08 PM   #2
1981 31' Excella II
New Market , Alabama
It should be vinyl coated aluminum. I think some 90's trailers had some sort of fabric glued to the aluminum. Sorta like a car headliner. If it is the vinyl it can be painted. Just do a search on here.
Perry
Attaching images to ABS plastic Okiegent Upholstery, Blinds, Walls & Interior Finishes 19 09-05-2013 04:31 PM
abs plastic seams cracked rayandre Sinks, Showers & Toilets 5 02-15-2011 03:56 AM
How do you glue ABS fitting to ABS tank? Mike&Ali Waste Systems, Tanks & Totes 9 12-09-2010 07:19 PM
Question about sand & polish ABS Plastic bmklawt Cabinets, Counter Tops & Furnishings 32 03-22-2010 07:20 PM
"Tough as Tile" used on ABS Plastic? glacierrunne Sinks, Showers & Toilets 1 07-04-2006 06:07 AM
