Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 11-05-2002, 07:13 AM   #1
Profile:
Question Removing wallpaper from 76 tradwind
I just purchased a 76 tradewind. The previous owner started removing some of the wall covering and refinishing the wall. The bathroom door is in bad shape. They tore the wood removing the paper and left large areas of glue. What should I use to remove the rest of the paper without harming the wall? I also would like to know what works well as a replacement. I am not sure I want to re-wallpaper. I would really like to make this trailer very retro, so I am open to suggestions.
Thank you,
Lisa
Rennegarbe1 is offline   Reply With Quote
Old 11-05-2002, 04:08 PM   #2
Commercial Vendor
Profile:  Corona , California
Take the old material off, and replace it with "Ozite." It's a thin wall covering similiar to carpet.
Make sure you use an excellent adhesive.
inlandrv.com
airstreamparts.com
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 11-05-2002, 07:37 PM   #3
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
The older vintage Airstreams had Zolotone. Assuming you fill the gouges you mention, Zolotone is a great product for durablity & hiding imperfections. It's a "speckled paint-like finish" and available in many colors. It is more expensive than traditional paint but much more durable.
Here's a previous thread that talks about removing the vinyl & using Zolotone.
Here's a link to the Zolotone webpage.
Good luck!
Shari
Old 02-02-2003, 07:08 AM   #4
andreaszabo
Guest
Profile:
Posts: n/a
Hi,
I have some wallpaper delamination as well.
I would like to find some original wallpaper as
there is only damage on the underside of the overhead
bins and the bathroom door.
The room divider is the same pattern in vinyl.
Anyone have a roll of this laying around?
It looks more like contact paper than wallpaper.
--andrea
Old 02-05-2003, 05:52 AM   #5
Profile:
Replacing Roof locker contact paper
Andrea,
I tried removing the contact paper under my roof lockers. BIG NIGHTMARE. I just don't have the right tools to do what needed to be done. My soulution was to take my trailer to someone that specializes in redoing old airstreams. She is replaceing all the wallpaper on the walls and roof lockers. The paper looks like an off white swirl to me. You should be able to pick it up at any wallpaper store.
Good Luck
Lisa
76 Sovereign vs. 76 Overlander tin can luv 1976 Sovereign 14 09-13-2004 07:01 PM
62 tradewind - tires/wheels needed..... p.dow Tires 1 02-27-2004 09:24 PM
New Tradewind owner Tin Hut 1959-69 Tradewind 5 08-18-2003 07:24 PM
Odd VIN Number for Tradewind cherring Title, VIN & Registration 8 08-14-2003 01:03 PM
