Old 10-13-2010, 02:49 PM   #1
1967 26' Overlander
orange , California
Removing wall vinyl from (nterior)
I like many attempted to remove the wall vinyl with compounds, a heat gun, and brut strength with not too much success. I decided to paint over it and used a paint stripper called JASCO ( use the kind that says sprayble on the front, when applied it melted the paint and primer off the vinyl wall covering like butter. After I wiped the paint off I noticed a piece of the vinyl had bubbled up. I applied a second coat and waited for about ten minutes and the vinyl started to bubble up from the aluminum skin inside. It is not easy or fun work but 10 hours in and my 1967 26’ Overlander is almost an all aluminum interior. The aluminum underneath looks great and is in perfect condition.
M67overlander is offline   Reply With Quote
Old 10-13-2010, 02:56 PM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
There is a trick to amplify the results - once you've rolled on the gel cover it with a sheet of drop cloth plastic to keep it from evaporating - it concentrates the solvents against the vinyl, and (I think) helps in removal process if you can peel and scrape into the sheeting to bundle it up and discard it...
Old 10-14-2010, 09:10 AM   #3
1967 26' Overlander
orange , California
Thanks for the tip, i'll try that on the second half of the removal.
Old 10-16-2010, 08:30 PM   #4
1961 16' Bambi
Sammamish , Washington
wall vinyl
Is wall vinyl the paint that was put on the early airstreams? Mine is a 61 Bambi. I would love to get down to the silver inside.
EssieBlue is offline   Reply With Quote
Old 10-17-2010, 01:53 PM   #5
1967 26' Overlander
orange , California
interior vinyl
I'm not sure on the 61 Bambi but on the inside of my 1967 Overlander there was a coat of paint and underneath that is a vinyl that looks cloth like as it has a cloth pattern. You coud try to remove some in a spot that does not always show and see what happens. The off white brown stuff is the vinyl. I'll post some of the finished walls when I get back to the trailer.
Removing Interior Vinyl Wall Covering 1970s silversafari Upholstery, Blinds, Walls & Interior Finishes 36 04-19-2018 12:22 PM
Vinyl on shower wall PatandLane Sinks, Showers & Toilets 9 04-22-2012 02:43 AM
Yet another Vinyl wall question Jim & Susan Upholstery, Blinds, Walls & Interior Finishes 4 11-19-2007 08:25 PM
Shower vinyl wall covering replacement. capehoorn Sinks, Showers & Toilets 0 05-19-2006 02:03 PM
Diamond Plate Vinyl Wall Covering swebster Upholstery, Blinds, Walls & Interior Finishes 0 05-14-2005 07:56 PM
