Old 06-08-2006, 12:55 PM   #1
1964 19' Globetrotter
jonesboro , Arkansas
removing paint
The previous owner of our 64 globetrotter painted the walls white. Any suggestions on safely removing the paint so we do not hurt the walls?
cpinkston is offline   Reply With Quote
Old 06-08-2006, 01:13 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
By not hurting the walls, do you mean the Zolatone beneath the paint or the aluminum?
You can strip both the paint & Zolatone using the same products as the clearcoat on the exterior...if you are going to try to just strip the paint and hope to revive the Zolatone underneath, I doubt that would be very sucessful. If the paint is adhered well, and you want to get it back to "original" I would re-Zolatone over it, otherwise, strip it all off then re-Zolatone.
Kleen Strip, Bix, Citri-Strip are some of the products used for stripping...if you perform a "search" using stripper as a keyword, there will be other products that come up ~
Shari
P.S. Congrats on the '64 GT...a great trailer, I hope you get as much enjoyment out of ours as we have ours.
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 5 08-07-2009 11:23 AM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 11:56 AM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 07:03 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
