Old 02-28-2016, 07:22 AM   #1
GypsyKarma's Avatar
1973 31' Sovereign
Atlanta , Georgia
Removing interior skin
I need to remove the lower interior skin to work on the belly pan. I hear I have to drill out the rivets. Do I HAVE to put rivets back in, or can I use something else?
GypsyKarma is offline   Reply With Quote
Old 02-28-2016, 08:27 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
First of all, you do not need to remove the lower interior skins in order to work on the bellypan of a 70's vintage trailer. The skins do not wrap up over the C-channels like in earlier models. The entire bellypan can be removed from the outside without touching the interior skins.
Now in response to your question about riveting the interior skins in place, the argument for using aluminum mandrel pop rivets is the following:
1) They aren't going to get loose as you travel down the road (like a sheet metal screw might).
2) They provide a "weak link" so to speak. That is to say, if you get a vibration, or movement in the structure that might cause the pop rivet to shear, you would rather the rivet shear than to have the skin tear. If you put a stainless steel screw in there, the skin will tear around it.
3) Installing pop rivets is easy. You can use a $5 manually operated tool, and gain some forearm strength, or buy a ~$30 pneumatic tool from harbor Freight, which will get the job done and make it easy.
4) Finally, you are very likely never going to open up those panels again anyway. Hopefully the repair work you are doing will last for decades and not require intervention anytime soon. Besides, once you have installed all that cabinetry, bathroom, galley, gauchos, etc., those lower skins won't be easily accessible anymore anyway.
Good luck!
Old 02-28-2016, 01:33 PM   #3
1975 Argosy 26
Tulsa , Oklahoma
I'm in the process of restoring a 1975 Argosy 26', and have dropped the pan and lower skins/banana wrap. I highly recommend the Rivet removal tool from Vintage Trailer Supply:
http://www.vintagetrailersupply.com/...-p/vts-497.htm
It saved me a ton of time and frustration.
Good luck on your restoration adventure !
DDOK is offline   Reply With Quote
Old 02-28-2016, 09:19 PM   #4
Belegedhel's Avatar
Houston , Texas
Further follow-up: The bellypan on a 70's vintage trailer should be held in place by pop rivets. If you find yourself drilling out bucked rivets, you are very likely drilling the wrong ones.
good luck!
Old 03-07-2016, 09:31 PM   #5
1975 Argosy 26
Tulsa , Oklahoma
I'll be putting my pan back on in a month or so, and plan on using mostly sheet metal screws.....In my 1975 Argosy 26' I did have a few buck rivets on the bottom side of the pan I had to contend with when I removed it, but not many. Most were the smaller 'slightly beefier' pop rivets.
Removing interior skin mgjurina Ribs, Skins & Rivets 13 06-24-2015 10:49 AM
Removing pop rivets on interior skin? kokomoscalls Upholstery, Blinds, Walls & Interior Finishes 2 02-16-2014 03:59 PM
interior skin scrap for exterior skin patch? badger Ribs, Skins & Rivets 1 06-12-2010 07:56 AM
Removing interior skin-Overlander Zeppelinium General Interior Topics 15 11-18-2008 10:25 AM
removing the interior skin brandok General Interior Topics 3 02-25-2007 01:09 PM
