Old 12-24-2012, 07:31 PM   #1
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
Removing glue from aluminum walls
Hi,
We have a 2007 Safari 27FB we've just purchased. The previous owner stuck those clear plastic hooks with adhiesive on the interior aluminum walls. Can anyone recommend a product to remove the glue without affecting the finish?
Thank you!
Ron
Ronman is offline   Reply With Quote
Old 12-24-2012, 07:41 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Goo Gone or a heat gun with a plastic, not metal, putty knife.
Old 12-25-2012, 01:10 AM   #3
Ronman's Avatar
Yo, Lu...
Thanks for the solid advice! I have both solutions in my arsenal and will try the heat gun first. chemical removal can leave a mark!!
Thanks again,
Ron
Old 12-25-2012, 08:55 AM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Ho, Ro
Old 12-25-2012, 09:00 AM   #5
1994 28' Excella
Paris , Ohio
Try WD 40, I have good luck with it. Hope it works.
trapperman33 is offline   Reply With Quote
Old 12-26-2012, 10:58 AM   #6
Ronman's Avatar
Thanks, Trapper!
Old 03-24-2013, 09:09 PM   #7
Ramble On's Avatar
2004 28' International CCD
rockwall , Texas
WD 40 worked for me
Ramble On is offline   Reply With Quote
Old 03-24-2013, 10:59 PM   #8
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
adhesive removal
I use a product called De-SolveIt. You can find it at Drug Mart, Walmart, Lowes...It takes off grease and all kinds of goo. Use it on labels, chewing gum etc. Good luck with your work.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 03-25-2013, 09:11 PM   #9
Ronman's Avatar
Thanks, Larry! Appreciated!
