Old 12-14-2011, 10:24 AM   #1
ASNomads's Avatar
1978 28' Ambassador
Byfield , Massachusetts
Remove Insulation Adhesive
Hi everybody,
We are just getting done gutting our Airstream. We got rid of the pink fiberglass insulation and would like to remove the yellow adhesive, duck tape, etc. and clean those walls.
We tried Goof Off, but that didn't seem to work. Any ideas on products, if possible "Green" ones. Anyone tried Soy-It? A bit pricey but maybe worth if after smelling Goof Off for just a few minutes
Thanks for any advice.
Kiera & Georgie
ASNomads is offline   Reply With Quote
Old 12-14-2011, 11:38 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I used a circular scrub brush chucked in a electric drill to rub off the fiberglass shards bound to the glue on all the panels and wiring bundles. Lots of fun in mask and respirator, locate a tyvek full suit if you try this, I'd post a picture of my fuzzy self afterwards but it would be bad for morale and scare the horses... but it did clear the spanish-moss effect off the wiring.
A couple of months later when the shell had been lifted off and standing free I graduated to a 3000psi 3-gallon-per-minute gasoline pressure washer on the shell interior panels to worry the factory spray adhesive. I didn't have much luck removing the swaths of proper adhesive coverage but it erased the over-spray mist that fogged the shell and the surface residue build-up from 40 years to brighten up the interior nicely - or reduced the ugly by at least 50%.
Having the mirror smooth finish back would help keep sun shine heat-load down the same way as having a layer of reflective insulation would - the smooth surface helps keep energy from jumping from the solid to air, plus a physical property of aluminum is it does not radiate Infrared Light well that the glue residue will merrily be beaming off.
I'd love to accomplish a clean interior but will not subject myself to the solvents required (I've been told try Acetone) so will paint the inside shell with insulating paint instead, then a coat of aluminum radiant barrier paint before anything else happens...
Old 12-14-2011, 03:12 PM   #3
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Cleaning off adhesive and insulation
I did this same thing before and went through several chemicals that didn't work. I ended up using cooking oil and although it didn't make the stuff just fall off, it did work. I smeared it on the walls and let it soak for a couple days then scraped stuff off with a plastic scraper and wood pieces.
Try it on a panel and see what you think. It's cheap too!!!
tinbender is offline   Reply With Quote
Old 12-14-2011, 06:05 PM   #4
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
I am with Wabbitteer on the pressure washer. I used it on our 60 Tradewind to remove insulation, glue, and tape residue off the aluminum frame and skins with relative ease. I don't know if the glues are different from the 60s to the 70s. The pressure washer also keeps everything wet so no airborne stuff.
Interested to know how you get it done. Good luck.
Name:	Isabel restoration 003.jpg
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 12-15-2011, 12:16 PM   #5
ASNomads's Avatar
1978 28' Ambassador
We gona try out some more products this weekend. I imagine an adhesive/paint stripper of some sort.
I'll let you know how it goes...
Old 12-20-2011, 06:16 PM   #6
ASNomads's Avatar
1978 28' Ambassador
I tried a paint stripper form the local home depot called Klean-Strip which did not really work, still a lot of scrubbing and no easy peeling.
I guess the reviews on the internet partly confirm the mediocrity product.
Search goes on or wait till spring when the shell is off , to go in with a pressure washer
Old 12-20-2011, 06:44 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
Klean Strip Premium Stripper
Klean-Stripģ
Methylene chloride 60.0 -100.0 %
Methanol 10.0 -30.0 %
Stoddard solvent / Mineral spirits 1.0 -5.0 %
Fail. Thanks for the information!
Old 12-16-2017, 01:09 PM   #8
Houston , Texas
Informative, thanks
Hola Everyone
That glue actually had some magical properties. Didn't realise it is imperative to remove all of it, was thinking we could just add more glue and put the silver reflection stuff on top = wrong!!! Needs to be shiny for insulation, very good to know, want to do this renovation right the first time. I want to remove it anyway, there is tons of mould and dust which contains rat fecal matter. I also tried eucalyptus oil, Goop Off, a bunch of different solvents and nothing, its still there in all its browny yellowish glory, mocking my efforts. We not only have that but that goopy white sealant stuff, we can remove that with a scraper, most of it is a mix of cracked goop and mould, so it has to go. It was used very liberally around everything, including the door and all the windows, it all needs to be replaced, its disintegrating anyways.
The power washer is one of my favourite toys after the chain saw. Its going to be tons of fun cleaning the walls. Thanks for the heads up, was worried about the power washer pressure denting the walls more, but the walls are already dented, ugh....... and so are a couple of ribs (tree from Hurricane Ike falling on it)......one day at a time
Have a great weekend
Joie
joie is offline   Reply With Quote
Old 12-22-2017, 04:16 AM   #9
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
My 67 had a black tar like substance spattered on the inside walls to hold the insulation in place.
I replaced mine with Reflectex.
If you use this be sure to leave an air gap on both sides of the Reflectex otherwise the insulating properties are nill.
Good luck with your project!
Dingo Girl is offline   Reply With Quote
Old 12-30-2017, 07:42 PM   #10
1970 25' Caravanner
Incline Village , Nevada
Glad I read this thread for what not to use. So far product failures with Goof-off, Klean Strip, eucalyptus oil. Some results with pressure washer.
Cooking oil....works well on the sap I get on my hands. Going to try this on the walls.
Jeremy9107 is offline   Reply With Quote
Old 01-01-2018, 10:45 PM   #11
1970 25' Caravanner
What is Xylene?
Answer : The stuff that removes insulation adhesive.
I tried the cooking oil. No help.
I tried Krud Kutter with the purple label. No help.
Didn't bother with the others mentioned in this thread due to reported failures.
Had a bottle of Xylene laying around, worked like a champ. Applied with spray bottle. Waited 15 minutes. Scrubbed off with 3M pad and scrub brush.
Old 01-01-2018, 11:09 PM   #12
2007 22' International CCD
Be careful. Keep area well ventilated. That stuff can be very flammable and itís not good to breathe...
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 01-05-2018, 09:28 PM   #13
1970 25' Caravanner
How about Zep?
Update from our efforts.
Xylene works but evaporates quickly and takes a lot of effort.
Goof Off Graffiti remover works too (principle ingredient is Acetone) but same troubles as Xylene.
Has anyone ever used Zep Industrial Purple Cleaner & Degreaser for this purpose?
adhesive, remove, walls
Trying to decide on floor insulation or none at all perryg114 Repairing/Replacing Floor &/or Frame 1 09-20-2011 01:52 PM
Dow Safetouch insulation 2vets General Interior Topics 3 07-13-2011 07:25 PM
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 08:26 PM
Black adhesive behind insulation. Darkspeed General Interior Topics 2 06-17-2011 10:55 PM
Fiberglass vs Cotton Insulation GeocamperAS General Interior Topics 13 03-09-2011 07:22 AM
