Old 04-18-2007, 08:44 AM   #1
rek
Santa Fe , New Mexico
Removal of Zolatone Paint from Interior Walls of '54 Wanderer
Hi, Everyone -
Does anybody have any advice on how to strip original Volatone paint from the interior walls of a vintage AS trailer in a way that doean't damage the underlying aluminum? The trailer in question has been completely gutted at this point.
Many thanks,
rek is offline   Reply With Quote
Old 04-18-2007, 09:20 AM   #2
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Zolatone can usually be removed by using Kleen Strip. Be careful with the stuff - it's pretty nasty but it will do the job. You can also do a search for stripper on the forums - you'll end up with lots of info. Good luck!
Mel
Mel is offline   Reply With Quote
Old 04-18-2007, 09:35 AM   #3
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
I just stripped my 53 Flying Cloud. We used Jasco paint stripper with a #1 steel wool and a towel. This seemed to work best for us. We also removed the interior skin, which made it easier. I hope this helps. Good luck
1953 Flying is offline   Reply With Quote
Old 04-18-2007, 02:04 PM   #4
rek
Wow. That sounds like quite an undertaking. Is it really necessary to remove the interior skin - say, for example, to be able to hit the crevices and shhet overlays - or did you do that just to expedite the work?
Old 04-18-2007, 02:39 PM   #5
1953 Flying Cloud
Images: 8
Yes it was quite a job. Full retro fit. I did it for 2 reasons. I had little critters living in the trailer walls that was giving off a real bad smell. The other reason it was easier to scrape the domes. But if you don't have to remove the inner shell, I wouldn't. You just might open a can of worms.
Old 04-18-2007, 05:37 PM   #6
rek
Thanks for the further insight. You're right. I don't want to open the walls up. And I don't have any funny smells/critters. So, knock on wood.
Good luck with it all!
Old 05-02-2007, 10:48 AM   #7
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Stripping down the bath of the Trade Wind and plan on leaving it naked aluminum. Didn't you get swirl marks with the steel wool?
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 07-12-2007, 01:17 PM   #8
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 26
you will get swirl marks unless you go all in the same direction.
we used #2 or #3 then finished with 0000. lacquer thinner is a must.
dip the steel wool in it, then use this to remove the stripper... then again with rags and lacq thinner till its clean.
after its all done you can come back with CLR (calc, lime, rust) and 0000 SWool and 'comb' it out to get a factory brushed finish.
here's some pics of how it turned out.
ID:	41083   Click image for larger version
Doug
59er is offline   Reply With Quote
Old 07-12-2007, 01:36 PM   #9
1953 Flying Cloud
Images: 8
swirls
Yes we got swirls, but we repainted it with zollotne paint, so it didn't matter to us. 59er has the right idea, if you are going to leave it bear. That was to much work for me and to modern looking for our taste. Good luck
Old 10-28-2007, 09:43 PM   #10
denellen's Avatar
2007 25' International CCD
1964 19' Globetrotter
2012 Interstate Coach
vero beach , Florida
Question Zolatone repaint
Yes we got swirls, but we repainted it with zollotne paint, so it didn't matter to us.----
How did you prep the bare aluminum prior to repaint? Did you use the water base Zolatone? How difficult was it? Did the results meet your expectations?
My trailer is currently completely gutted and although I could probably clean the interior acceptably at this time, I'm contemplating a color change and the Zolatone liturature makes me wonder if it might be too dificult to achieve a consistant result.
Thanks for any insight you may be able to provide.
Dennis
Dennis & Ellen
07, 25' Ocean Breeze
64, 19' Globetrotter
Air #7609
denellen is offline   Reply With Quote
Old 10-28-2007, 09:51 PM   #11
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Dennis
Hi Dennis, Take a look at Norcalbambi's thread. He did a repaint and color change with Zolatone. I have seen the results. It looks fabulous !
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 10-30-2007, 12:07 AM   #12
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Thanks Chris!We did repaint the zolotone in our 1963 Bambi. To prep it all we did was scrub the walls with 409, rinse well and repaint. Stuck like glue! We were very pleased with the results. Spraying is a bit tricky, but with the right equipment it will work well. We learned one lesson the hard way, don't try to skimp on the paint... purchase enough plus a little. You won't regret it!Zolotone comes in many, many hundreds of colors, so if you ask or even look at the zolotone web site, there are more than you might see there! About everything you might want! Good luck.Mrs. NorCal Bambi (traveling in S Tardis ~ from the Great State of Jefferson)
CaddyGrn is offline   Reply With Quote
Old 10-30-2007, 06:28 AM   #13
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
My favorite stripper has always been Cindy, nice girl with all the right moves! Oh, wait a minute, wrong forum, wrong type of stripper...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 10-30-2007, 08:46 AM   #14
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Now Bob - be careful! The wife may take the keyboard away! : >
Marc
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 07:03 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Repainting with Zolatone 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 3 06-10-2002 09:58 AM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
Zolatone Paint Question ALANSD Upholstery, Blinds, Walls & Interior Finishes 3 03-05-2002 03:25 PM
