Old 10-30-2007, 11:15 AM   #15
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If you use plain steel wool to give you a brushed finish you will leave small pieces of plain steel embedded in the aluminum. If the unit is stored over the winter condensation on the walls may cause them to rust and you will get small red rust spots. I suggest you use Stainless steel pads or oxalic acid wash the walls after you are done if you use regular steel wool.
Old 10-30-2007, 02:36 PM   #16
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Originally Posted by 3Ms75Argosy
Now Bob - be careful! The wife may take the keyboard away! : >
Marc
Nah, Liz is cool with my past life (I played baritone sax 6 nights a week for the strippers in a big band when I was in college)...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 10-30-2007, 04:38 PM   #17
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We just stripped several layers of paint and 98% of the Zolotone on the interior of our '56.
It's gutted and we are replacing the floor - so it's gone too. We used two different 'safe' strippers because it is enclosed and overhead. We used Napier Remov-all and Citristrip. Both worked. Citristrip smelled 10X better than the Napier and it's readily available at Home Depot whereas we had to order the Napier. We applied one coat, let it sit for 10-15 minutes then power washed it off. I think the Citristrip worked better than the Napier in one coat. It was not our goal to go down to bare metal because we are going to re-Zolotone and wanted to leave some "tooth" for it to stick to. I'm certain the Citristrip would take off all the Zolotone with another coat, especailly if you don't have all the latex paint we did over it. Napier might do it in a second coat, but most likely two.
You can see our results here
Shari
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 07:03 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Repainting with Zolatone 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 3 06-10-2002 09:58 AM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
Zolatone Paint Question ALANSD Upholstery, Blinds, Walls & Interior Finishes 3 03-05-2002 03:25 PM
