Originally Posted by wheelygoode
Airstream used that same style for a long time - we have a '97 LandYacht 30 motorhome done the same way., and I was planning to just use the present t upholstery as a pattern, but of course that wouldn't change the style at all. I really like how yours looks! Any tips? Like how much fabric, how you tackled the angles of the back cushions, did you use zippers, etc.?
Thank you for posting the pix!
I think I purchased eight yards of fabric, seven probably would have been enough because I still have some left on the roll. That was enough for both benches and the padded piece that runs between the benches on the wall.
I did not use the original upholstery as a pattern since the cushions were split for some sort of decorative purpose. They had two separate zippered sections which I did away with when I opted for one piece cushions.
Sailrite.com has cushion making videos, I followed these and it was pretty straight forward.
I did use zippers, I used a #5 zipper, I picked up a dozen yards of zipper and pulls from a local industrial sewing shop.
The angled backs where the trickiest part. The first one I did the side plaques were a little long. I think I figured out to make them the same length as the edges of the top plate and that took care of the problem on the second cushion.
-Alden
