Old 07-31-2009, 09:48 AM   #1
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Question Rear bath end cap removal
Evidence of visitors living in the "attic" seeping down from behind the end cap and tiny "raisins" behind the vanity lights when the bathroom was gutted for floor replacement. I'd like to remove the cap to clean whatever is left up there and check/replace insulation. The only way I can see to get the end cap down is to completely remove the ceiling panels. The folded lips on the side ceiling panels holding the top panel in place won't allow me to curl the panels back to drill out the blind rivets holding the cap. Is there an easier way?
Birdwell57 is offline   Reply With Quote
Old 08-01-2009, 03:02 PM   #2
sbreide471's Avatar
1969 27' Overlander
woodinville , Washington
hello i have a 69 overlander with a fiberglass overhead in my bath that cracked i took mine out with a jigsaw but if you wont to keep it
i cant help you its all one peice sorry
sbreide471 is offline   Reply With Quote
Old 08-01-2009, 03:11 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Thats just about the only way is to get that sheet metal out of the way. sometimes you can shoe-horn the cap down if the lower panels and all bathroom pieces are removed, still will have to remove the row of rivets where the ceiling metal overlaps the fiberglass or vice versa.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 08-01-2009, 03:14 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Have a 68 Trade Wind with a couple of dents above the rear window. I was going to take the fiberglass end cap out since the trailer is gutted for new floor to have access to the dents. After looking and drilling, mine is like yours, either take all the ceiling panels out or forget it. I am just going to live with the dents above the rear window, the time and effort to take out the end cap is just not worth it to me.
Old 08-01-2009, 06:16 PM   #5
airstreamjudy's Avatar
1968 24' Tradewind
Largo , Florida
I also have a '68 Trade Wind. Getting the lower pieces out and back was a nasty job. I also have a recent dent (acquired when I purchased the a/s getting it out of the resting place it had been in for 18 years) that I wanted to push out - we took a look at the interior end cap and gave up. I also will be living with a dented rear upper panel.
I think the dings and dents just give us vintage a/s a style of our own. Anyway I don't see it unless I go out and walk around the back. If my neighbors complain about my dent I'll engage them to do the repairs.
JudyW
airstreamjudy is offline   Reply With Quote
Old 08-02-2009, 12:17 AM   #6
VIKING's Avatar
Boulder Creek , California
I removed my interior endcaps along with everything else recently. The insulation was in really bad shape and there were lots of mouse trails in it. I did have a hard time taking them out, but the really hard part was taking down the ceiling panels. In mine the two panels that make up the ceiling are buck-riveted together and installed as one piece, which is about seven feet by twelve feet.
After removing all of the insulation the "old trailer" smell was completely gone. It hadn't been very bad, but the difference was noticeable. I'm installing new foil faced insulation everywhere.
68 twind and airstreamjudy, the dents you have can sometimes be pulled out part or all of the way. I've heard of people using suction cups, or hot-melt glue and sticks to pull dents on upper panels out. It may leave creases still but if you can get most of the dent out it looks way better.
Rich
VIKING is offline   Reply With Quote
rear end cap removal. garthbf Ribs, Skins & Rivets 2 08-15-2006 09:21 PM
Shower pan removal in a 79 (rear bath) wdm Sinks, Showers & Toilets 0 06-11-2006 05:44 PM
Interior End Cap Removal: HELP! sierrajb Member Introductions 6 02-02-2006 01:19 AM
End cap replacment till Exterior Restoration Forum 6 12-31-2004 04:30 PM
front, end cap George Ribs, Skins & Rivets 9 04-07-2003 04:48 PM
