Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 01-28-2008, 11:41 PM   #1
flashgrbiv
Profile:  1965 17' Caravel
Hood River , Oregon
Question Question - Remove wood panel
Right by the door in my Caravel I've got a panel of wood that frames the fridge box. That panel bottom has delaminated due to water damage, and I need to remove it. The problem is the top is solid and well glued to the counter, drawers, etc. How do I remove it without damaging the rest?
Any guidance would be appreciated.
Flash
flashgrbiv is offline   Reply With Quote
Old 01-29-2008, 12:44 AM   #2
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
If I hear the question correctly, I would cut the bad part out and place in a new panel, covering the joint at the cut with a decorative trim moulding.
Or are you talking about something totally different?
I'm a visual guy - can you post a photo of the problem?
Dave
Fyrzowt is offline   Reply With Quote
Old 01-29-2008, 12:53 AM   #3
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
On my trailer that panel is screwed down along the front edge and the bottom edge. Remove those screws and the panel pulls out from the bottom and can be removed. Come to think of it, maybe the PO said he replaced that panel while he owned it, so maybe he separated it from the top.
Stephanie
Our family photo blog
Old 01-29-2008, 08:28 AM   #4
47WeeWind
47WeeWind's Avatar
Profile:  1948 16' Wee Wind
1964 19' Globetrotter
Denver , Colorado
Images: 13
Hi Flash:
Depending on how high the delamination extends upward from the floor, you might just screw a shiny kick plate over it and be done via a fast fix. I'm thinking a 4" or 6" high kick plate of stainless or aluminum might look OK down along the floor. Easy is as easy does ... Or just cut out the rotten section horizontally with a sabre saw and put in a new piece of matching wood or a new kick plate with a lapping support strips invisible on the inside.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
47WeeWind is offline   Reply With Quote
Old 01-30-2008, 11:50 AM   #5
flashgrbiv
Hood River , Oregon
47weewind,
Wow! That's a great idea that I had not considered. I'm gonna do it.
Old 01-30-2008, 12:29 PM   #6
Stefrobrts
Stefrobrts's Avatar
Good one, Fred, and I'll bet that will look really nice too!
Stephanie
Old 01-30-2008, 12:39 PM   #7
Globie64
Globie64's Avatar
Profile:  1964 19' Globetrotter
The Sea Ranch , California
Hey. I did the same (kick plate) with some oak base molding, simple 1/4" eased edge... maybe the metal is a good idea if water is a reoccuring problem; the oak matches the interior and kind of disappears.
Cheers
Peter
Wherever you go, there you are
Globie64 is offline   Reply With Quote
wood walls in an A/S? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 26 03-10-2008 12:35 PM
fuse panel question BigSky Electrical - Systems, Generators, Batteries & Solar 6 02-26-2007 08:45 PM
What wood would you use? Safari Tim Cabinets, Counter Tops & Furnishings 71 02-18-2005 02:36 PM
Tile and Wood dbtolman General Interior Topics 2 09-09-2004 05:21 PM
Cabinetry wood till Cabinets, Counter Tops & Furnishings 9 06-18-2004 08:50 AM
