Old 09-27-2016, 11:01 AM   #1
1977 31' Sovereign
Tallmadge , Ohio
Pre-Painted Aluminum for Inner Shell
We are thinking of replacing the inner shells with pre-painted aluminum sheeting. Something like is available here:
http://www.wrisco.com/product/aluminum-sheets/
Has anyone done this or is there any reason not to do it?
Thanks!
PurdyWagon is offline   Reply With Quote
Old 09-27-2016, 12:03 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Since most of the interior skins require you to cut them to a custom shape/size, this will expose a raw edge that will be sharp and not painted.
Old 09-27-2016, 12:35 PM   #3
1977 31' Sovereign
Tallmadge , Ohio
Definitely a good point. Thanks!
Old 09-29-2016, 02:43 PM   #4
ericpeltier's Avatar
Superior , Colorado
I have been painting aluminum to go back into my Streamline. It's really not that hard and I think the pre-painted MUST be more expensive than the raw sheets?
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 09-30-2016, 11:33 AM   #5
vanster's Avatar
1967 17' Caravel
Oakland , California
I had all the interior skins anodized. I found a shop that could dip 10 x 4ft sheets
vanster is offline   Reply With Quote
Old 09-30-2016, 02:06 PM   #6
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sausalito , California
Send a message via Skype™ to Jenniflow
How does anodized look?
Any pics of how it came out?
Thanks!
Jenniflow is offline   Reply With Quote
Old 09-30-2016, 02:13 PM   #7
chrisetmike's Avatar
1967 26' Overlander
Haute-Aboujagane , New Brunswick
Can I ask why, was it aesthetic reasons or a structural one ,or a bit of both. I would like to have an aluminum interior but I am not sure if I want to clean smudge marks all day . Annonized aluminum might be the answer.
chrisetmike is offline   Reply With Quote
Old 10-03-2016, 04:46 PM   #8
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands , Illinois
Removing and reinstall
Thanks!
Why would U remove the perfict aluminum to replace it with painted. Why not just have a body shop paint what is in the trailer now. Don't think replacing it will be as good as an install as what is in there now.
rmatkovich is offline   Reply With Quote
Old 10-03-2016, 04:48 PM   #9
2000 34' Limited
1985 25' Sovereign
Why not just go to a body shop and see if they can paint what U have in there now. To remove the aluminum U will have to have it gutted and I do not think the replacement will be as good as what is there now.
Old 10-03-2016, 08:44 PM   #10
1979 23' Safari
Wayland , New York
Don't see to many problems, but cutting and installing without scratching up the paint will be very difficult.
I replaced all my interior aluminum skins. Took a little creativity. Sanded, solvent cleaned then primed(etching) each piece after cutting then put them up, then painted with a roller.
Why replaced, full of large holes from PO's bad repair attempts and one partition support had punched through the ceiling.
Old 10-04-2016, 10:19 AM   #11
vanster's Avatar
1967 17' Caravel
I don't have any pics of the anodized sheets as I just removed everything so we could go back and seam seal the entire inside with Wurth seam sealer. As usual we do everything a bit backwards. Giant PIA but the sealing up the inside is a big deal and thankfully cleko's
get us through it. The anodizing was done in a satin finish that does not mark. I'm lucky to have found a shop that can dip 12 x 4ft sheets of aluminum at the cost of about $90 per sheet. They are in Emeryville Ca a few blocks from Pixar.
As soon as I get all the seams sealed we will re install the panels and we are going to do the forward end cap as well the back most likely will be wood.
Wanted: Pre 1970 Vintage Airstream Shell with bath innerbeach Airstream Classifieds 1 02-10-2014 03:49 PM
Inner shell Rivet Removal Vblgrl9 General Interior Topics 7 10-07-2011 03:26 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 05:31 AM
Pre-fit Shell? NorCal Bambi Ribs, Skins & Rivets 16 08-15-2006 11:17 AM
Inner shell condensation! NorCal Bambi Ribs, Skins & Rivets 18 01-18-2006 01:52 PM
