Old 05-31-2006, 10:26 AM   #1
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Pleated Day/Night Blinds
The strings on the pleated day/night blinds in my '94 LY have worn and in some cases the blinds are not able to slide. Does anyone have any instructions on how to restring these blinds. From what I have read, there are some "clutches" that hold the blind in position, and these may also be broken. I can't seem to find clear instructions on the web on how to do this.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 05-31-2006, 08:19 PM   #2
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I would suggest contacting the manufacturer. If you were to take one of the blinds down the manufacturer should have their name on the inside of the head-rail. Good luck to you.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-31-2006, 09:04 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
I've done lots of these. It is not a hard process but it is a little painstaking. E-mail at lew@gorge.net as I have a few questions about how they are assembled and I can then advise you how to restring them
Old 06-01-2006, 10:06 AM   #4
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I just ordered new string and the plastic buttons from United shade in Elkhart, In 1-219-262-0954. Thats the name and number on the shades, I think the area code has changed and I found new area code at web site. They e-mailed instructions and a diagram. My shades were from a 1997 Airstream. The buttone on mine are brittle and breaking.
Paul
airstream4 is offline   Reply With Quote
Old 06-01-2006, 01:59 PM   #5
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Can you email me the instructions you got from United Shade - howardk@zed.net - TIA
VE3JDZ
AIR 12148
Old 06-10-2006, 11:38 PM   #6
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Did you get your directions? I found this on rv.net posted two weeks ago.
just so happen to have 2 diagrams on restringing day/night shades.They have helped other people out from what I hear.E-mail me and I`ll forward these diagrams over to you. johnw@rcn.com
Posted by RV JOHN on 5/30/06
http://www.rv.net/forum/index.cfm/fu...d/17683473.cfm
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 06-22-2006, 06:58 PM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
More info re: manufacturer
I finally got my rig back from the AS dealer (various exterior items needed attention, one of which was that the screws that fasten the exterior walls were starting to work loose). SO I was able to see the label on the blinds -- it says "Pleated Shades by EDI - Elkhart IN, Anaheim CA"
A Google search came up with a coment on a forum as follows:
"EDI day night shades are mfgd in Elkhart, Indiana. Your dealer should have the phone number and address. I was at the factory last year to have some repair work. Try United Shade, Elkhart, Indiana at 219-262-0954."
I'll be calling United Shades tomorrow.
Thanks for all the info you've all provided to date.
VE3JDZ
AIR 12148
Old 06-24-2006, 11:04 PM   #8
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Another complication - 3 string shades
I called the folks at United Shades. They told me that EDI went out of business, but they probably could help me. Then came the complication - - United Shades makes their day/night pleated shades with either 2 strings or 4 strings. The EDI ones I have are 3 string - and United Shades said that they don't have any instructions on how to re-string those with 3 strings (i.e., there are 3 strings running through the "rat holes" in the pleated shade).
I also noticed that I have 2 strings in tandem coming down on each side, and they are tied off at the bottoms to the plastic "button".
Has anyone restrung an EDI day/night shade that has 3 strings? If so, can you tell me how it is done?
VE3JDZ
AIR 12148
Old 06-25-2006, 07:34 AM   #9
Zed2's Avatar
1993 21' Sovereign
Plano , Texas
Try:
Speciality Window Coverings
1655 Gateway CT.
Elkhart, IN 46514
(574) 262-5190
Keith
Zed2 is offline   Reply With Quote
Old 06-25-2006, 11:44 AM   #10
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Thanks, Keith. I'll call them tomorrow.
VE3JDZ
AIR 12148
Old 06-26-2006, 08:05 PM   #11
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
On the basisi of the information received from United Shades and some info gleaned through Google, I made the plunge and removed the smaller of the 2 pleated shades that needed to be restrung. I bought the string at Walmart and also bought a wool needle (large eye and blunt point). I was able to restring the blind and it is up and working fine. I made a sketch of the route the strings take - here it is for those who may need this info:
VE3JDZ
AIR 12148
Old 01-23-2010, 12:04 AM   #12
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Day/nite window shades for '07 Bambi
I'm not wild about the mini-blinds on our Bambi. I like the looks and function of the day/nite shades, but don't know whether I should order them through an AS dealer or from a factory. Also don't know if they can be adapted to the mini-blind frame and hold-downs, or whether drilling and different hardware are req'd. Any info?
-Jerry
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 01-23-2010, 05:58 AM   #13
Lily&Me's Avatar
Normal , Illinois
Our Interstate came with the day/night shades, which I then ruined 2 1/2 years later trying to clean them. Jackson Center replaced them for us, measured, ordered and installed. Not bargain basement prices, but reasonable, and they are a very neat and tidy way to cover windows in small spaces. We love them.
Old 01-27-2010, 03:18 PM   #14
Zed2's Avatar
1993 21' Sovereign
Plano , Texas
1655 Gateway CT.
Elkhart, IN 46514
Stephanie
(574) 262-5190
(574) 262-5350
and
United Shade - Donna Customer Service
http://www.unitedshade.com/
http://unitedshade.com/coloropt.php#shades
P.O. Box 2903
28605 CR 6 Elkhart, IN 46515 Telephone: (574)262-0954
877-262-0954
Cotton - Night shade
Alabaster - Day night
I believe both have been an OEM supplier to Airstream
Day/Night Pleated Shades Minnie's Mate Upholstery, Blinds, Walls & Interior Finishes 10 11-03-2004 09:03 AM
Blinds for my 1964 Safari Neenm Upholstery, Blinds, Walls & Interior Finishes 19 09-18-2003 04:33 PM
Curved WindowCurtain Railing Attachment winner Upholstery, Blinds, Walls & Interior Finishes 4 11-01-2002 08:14 AM
Need new weather stripping kit lizh Windows & Screens 8 08-30-2002 07:49 PM
Blinds ALANSD Upholstery, Blinds, Walls & Interior Finishes 35 04-01-2002 01:54 AM
