Old 05-15-2006, 08:03 AM   #15
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
If you find the pics of the Bisby, AZ campground one of the units they have on for rent has the end caps polished. Over the rear bed the reflection is stunning to say the least. My neighbours purchased my '58 Silver Streak and are busy doing a full monte' on it and in the process they intend to polish the end cap in the front at least. Once done I'll suggest they put pictures up. It's a look I want but not sure I have the patience to tackle it in my FC at this time. Maybe later in life when I've got more time on my hands over the winter.
Barry
safari57 is offline   Reply With Quote
Old 04-28-2010, 07:28 AM   #16
Fairbanks , Alaska
Hi, where did you get the aluminum?
Thanks!
Liz and Chris -- Follow our Full Time Adventures on http://www.gypsymoments.com
Visit my new Airstream renovation blog here:
http://www.AirstreamLoft.com
gypsychris is offline   Reply With Quote
Old 04-28-2010, 09:30 AM   #17
Road Ruler's Avatar
Images: 38
My bh also wanted the CCD look for our upgraded kitchen project so I bought an aluminum sheet from the local metal supplier. In our case I just cut to fit and laid the new aluminum over the existing wall. Looks good and has stood up well. There was a question about mold/mildew build up between the panels. When I get a chance I will have a look to see if that is happening.
Old 05-05-2010, 08:07 AM   #18
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 26
just found these pics of how our strip-job turned out. A LOT of (fumey) work but I think it turned out about like we had hoped.
we ended up by smoothing it all out with 0000 steel wool and CLR once all of the paint was removed. then wiped everything down with water to neutralize the CLR.
ID:	101820   Click image for larger version
Doug
59er is offline   Reply With Quote
Old 06-30-2010, 02:22 AM   #19
adobehome's Avatar
1962 19' Globetrotter
New River , Arizona
Doug. Looks great. doing the stripping now on just a few panels of my 62 GT. Please, what is CLR?
Judy & Bill
'62 GT
adobehome is offline   Reply With Quote
Old 06-30-2010, 03:06 AM   #20
Kevin245's Avatar
I believe he is referring to CLR which is a common household cleaner. CLR typically stands for Calcium Lime Rust.
Jelmar | We Clean More Than You Think - Home
Kevin
Eleanor Roosevelt
Old 06-30-2010, 06:36 AM   #21
3streams's Avatar
1948 22' Liner
1949 24' Limited
Springs , Pennsylvania
Here are some pics of a 1949 Limited with a stripped interior that we own- it came to us like that so I can't comment on how hard the process was- but I think it looks pretty good!
ID:	106047   Click image for larger version
April & Andy Hershberger
www.ClassicAluminumTrailers.com
3streams is offline   Reply With Quote
Old 08-09-2010, 06:15 PM   #22
Flysoncloud's Avatar
1953 21' Flying Cloud
Wentzville , Missouri
My results
I see this a old thread but just to bring some new people up to date on stripping......citristrip. I used it on the cloud with fantastic results. I put it on with a paint brush and let it sit for one hour at least. I used a very stiff scrub brush not a steal one. here are my results on one of the end caps. Again this was very easy to do with no smell and no skin being lost to the stripper.
I have read about the evils of drinking beer so I quit reading.
Flysoncloud is offline   Reply With Quote
Old 08-09-2010, 06:51 PM   #23
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
It looks great!
blmitch5 is offline   Reply With Quote
Old 10-04-2010, 12:56 PM   #24
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
wow....uoshane, was that covered with Zolatone before. amazing. the stuff in our 59 took AT LEAST three passes with the toughest stuff I could find, followed by a lacquer thinner wipe down. it was brutal.
your results are great. are you going to mirror polish?
Doug
Old 01-09-2011, 08:51 AM   #25
1983 31' Excella
Erin , Ontario
Looks great! I may soon be an owner of an '83 Excella. Same color interior wood and tambours(sp?). Are you still happy with how it has held up?
fab5 is offline   Reply With Quote
Old 03-18-2011, 10:53 PM   #26
bendavanza's Avatar
Oak Cliff , Texas
For the OP:
On Motorcycle aluminum, I use WD-40 and scotchbrite abrasive pads to get that look. You have to work in a single direction. I have considered doing my entire exterior that way, as mine is to banged up to look good if polished.
http://www.bendavanza.com
bendavanza is offline   Reply With Quote
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 09:32 PM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 07:03 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
