Old 08-24-2010, 10:08 PM   #1
1990 25' Excella
Pilot Hill , California
Peeling wall paper 1990 excella
Is there any special adhesive and or trick that can repair peeling wall paper on our 1990 excella?
Sierra Skier is offline   Reply With Quote
Old 07-27-2011, 01:21 PM   #2
1990 29' Excella
tatamagouche , Nova Scotia
we too have a 1990 Excella and the wallpaper in the shower is peeling of the wood panel. I as well would like to know if I can reglue said paper or do I need a plan B? What type of glue would work??
jhendy is offline   Reply With Quote
Old 07-27-2011, 01:59 PM   #3
1990 34' Excella
Waterloo , Ontario
We also have the same problem with our 1990 Excella 34. I tried spray on glue - didn't work. Our wallpaper has also shrunk a bit.
I think I'm going to peel it all off and paint the walls with a special water resistant paint.
DEWASSINC is offline   Reply With Quote
Old 07-27-2011, 03:38 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The "wallpaper" is actually a flexible vinyl film. After a number of years the plasticiser in the formula starts to evaporate and the film shrinks non-uniformally and that causes the wrinkles and lifting. You can try to re-glue it but it will be difficult to make it lay flat. You might have to even cut it. This will not look good and you might have to use some new bathroom rated vinyl "wallpaper" as a replacement. Painting is another potential solution.
Old 10-24-2011, 07:20 AM   #5
1994 30' Excella
Hanahan , South Carolina
We are planning to remove the wallpaper in our bathroom and paint but we don't know what to use to remove the current wallpaper. Any suggestions. Thanks very much.
Toppy is offline   Reply With Quote
Old 10-26-2011, 02:32 PM   #6
1986 32' Excella
Dover , Delaware
We had the same problem with the vinyl in the bath only on an '86 Excella 32'. Previous owner had tried several fixes with no success. Started in corner of shower. Then had problems in several areas. When I checked the board behind the section in shower found that it was not real smooth & felt paint might not be the solution. Also realized that removing the paper was going to be very difficult. Bit the bullet & redid the entire bath with the 4x8 sheets of vinyl from Lowes. Not the easiest job but turned out well. Did it in '04. I had owned unit for 5 yr. Is holding up very well also.
rbhinzman is offline   Reply With Quote
Old 10-26-2011, 04:42 PM   #7
1977 31' Sovereign
1989 34' Excella
3M has a spray contact adhesive no. 77 which does stick to the plywood and the vinyl wall paper. If there are no wrinkles, caused by shrinkage of the vinyl, it will come out looking not too bad.
Old 10-30-2011, 10:31 AM   #8
Elf1's Avatar
1990 34' Limited
Proud to be , an American
West Marine Wall paPER & Below counter sink
West Marine has a product...called "Six-10"
It is an epoxy binder.
It will glue ANYTHING. Word of caution, do NOT use it anywhere you ever want to lift, remove or have future access to.
I have used it with great success in this very area, travled from FL to AK, back to CA....no issues at all. The application can be a bit tricky. Not out of the tube, but id you have serious wrinkles....a small strip of 1/8 ply and some clamps if it is on your leading edge....or if in the corners you can use speing loaded curtain rods...small or lg.
As a closing thought, those of us that have the below counter sink...the one that is held on with clamps and is forwver droppping down or needing center support.....This is THE product. place a very god bead on the sink edge, pull the sink down once to assure that you have contact all the way around. ( add more if you dont) Then replace the sink, clamp in place with the original clamps and place the temp support in the morning. you will NEVER have any seperation or support issues again.
Cheers
Elf 1
Elf1 is offline   Reply With Quote
Stripping vinyl shower wall paper and replacing rtjbrewster Interior Restoration Forum 1 05-04-2008 10:30 AM
1990 Excella Where's the Speakers? ts8501 1993 Excella 1000 3 01-27-2008 01:07 PM
1990 excella value Jagger1956 Trailer Values 0 10-24-2007 08:14 PM
Peeling wall panels wacnstac Cabinets, Counter Tops & Furnishings 3 11-30-2006 08:11 PM
wall switch in Excella 1990 32' femuse Electrical - Systems, Generators, Batteries & Solar 3 03-09-2003 11:34 AM
