Old 02-06-2012, 10:38 AM   #1
2009 23' FB Flying Cloud
1959 24' Tradewind
1951 21' Flying Cloud
Northeast , Iowa
Painting over Zolatone
I've seen many threads of people wanting to strip latex to expose Zolatone, but I'm wondering about going the other direction. We have a 59 Tradewind that has zolatone, but it is dirty/grimy and hasn't yielded to our cleaning efforts, plus we are rearranging the interior so there are unevenly faded areas showing. We have the entire interior removed, so there will be seam edges showing when we reinstall the interior. Zolatone sounds very complicated to apply and expensive. It looks OK to me, but I'm not a big enough fan of it yet to put a lot of time and money to preserve it.
At the risk of sounding blasphemous to the vintage community, what are other options for painting the inside?
Any particular paints to use? Special primers?
Thanks for any input. This forum is a terrific source of information!
epperp is offline   Reply With Quote
Old 02-06-2012, 10:56 AM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I did not like the look of the old Zolatone on our 65 Safari so I cleaned it good then applied 2 coats of Zinser latex primer. Then I applied 3 coats of Valspar Elan Pearl finish latex. 1 day between each coat then 7 days curing time before I did any more work. It's been 3 years now and the paint job is still flawless.
ID:	150443   Click image for larger version
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 02-06-2012, 06:21 PM   #3
1959 24' Tradewind
Northeast , Iowa
Looks nice! I have not heard of Zinser primer before--is this a primer for metal surfaces?
Old 02-06-2012, 06:26 PM   #4
Lothlorian's Avatar
Loganville , Georgia
Our 73 has zolatone and it was sticky, grimey, dirty, and just plain nasty. we tried everything and nothing worked until we used Mr. Clean Magic eraser. It came back like new. The only thing we painted was the endcaps.
My 1960 we bought had been painted by the PO. We went to Sherwin williams and they gave us the primer and paint we would need. We sanded the sloppy drips from the po and repainted. It looks great.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 02-06-2012, 06:37 PM   #5
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I mad a mistake it is not Zinser. The primer we used is Kilz Premium. Your question made me go to the basement paint storage room to check. Sorry.
It has worked wonderfully. We also painted the interior of a 63 Overlander several years ago using the same system and it still looks great. I think the key is getting the old surface really clean before priming. Good luck.
Tim
TAC MI 14
Old 02-06-2012, 08:00 PM   #6
drunkensloth's Avatar
1965 17' Caravel
Knights Landing , California
I used two coats of glidden gripper primer and a behr topcoat at the advice of the home depot paint guy. I was a little concerned taking his advice, but it came out great. Our zolatone was nasty looking.
drunkensloth is offline   Reply With Quote
Old 02-06-2012, 08:19 PM   #7
1959 24' Tradewind
Northeast , Iowa
Thanks for your replies.
Cleaning is the best start for painting, but what to clean it with?
My first attempt, based on cleaning house siding, using TSP, bleach and warm water did not go well. It didn't make a dent in the grime/old cigarette smoke staining (I'm guessing at the source), and seemed to corrode any bare aluminum it splashed on.
I'll give the Mr. Clean eraser a try. Any other suggestions?
Old 02-06-2012, 11:22 PM   #8
Maniacal Engineer
barts's Avatar
Menlo Park , California
We used a heavy duty degreaser from Costco - OilEater. Wear gloves - it will degrease your skin otherwise; don't dilute very much. This stuff cleaned the vinyl, painted zolotone, .... works like a charm, and is not expensive. Also
removes oil spots from driveways, cleans parts, etc.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Painting all the sides of a new floor? supergg Repairing/Replacing Floor &/or Frame 11 10-10-2011 12:45 PM
Just finished painting, now have spots all over after drying?? dgreen78 Upholstery, Blinds, Walls & Interior Finishes 16 09-05-2011 07:05 PM
painting your argosy pavlova All Argosy Trailers 10 08-14-2011 03:58 PM
Remove the stove vent-hood for painting palmtreegirl Stoves, Ovens & Microwaves 0 07-27-2011 07:52 AM
Painting your roof, etc Lumatic Roof 0 05-15-2011 10:29 PM
