Old 07-21-2011, 04:41 PM   #1
Whitefawn
whitefawn's Avatar
1978 Argosy 24
Scottsville , Virginia
Painting over 1978 Argosy wallpaper?
We have one wall left that we did not replace in our 1978 Argosy, (it was the only one not abused by the PO and the vinyl-like wallpaper is intact). Now it does not match the new walls. Dare we paint it with the same paint we put on all of the other walls (which went from bare wood to primer to nice exterior grade latex paint)?? I would appreciate anyones thoughts about this...
Kathy
whitefawn is offline   Reply With Quote
Old 07-21-2011, 05:03 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Kathy!
While I haven't painted over any of my original Vinyl-Clad, I do know that the following is important if you plan to paint over Vinyl-Clad:
  • Thoroughly clean the material to remove all traces of grease, oil, and dirt.
  • Prepare with a primer designed to go over vinyl.
  • Paint with a top coat that is compatible with the primer and deisned for use over a vinyl product.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 07-21-2011, 09:28 PM   #3
meredith's Avatar
1965 24' Tradewind
silverton , Oregon
Kevin,
What kind of primer do I need to go over the vinyl?
I have poured over all these posts and it seems that everyone has done everything in the book and all have problems if they take a short cut or who know's why and then there are some that never have problems...
I'm lost.
So what kind of primer should I get to go over the vinyl and also the zolotone?
Meredith
meredith is offline   Reply With Quote
Old 07-21-2011, 09:38 PM   #4
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Meredith!
Prior to thoroughly cleaning the vinyl-clad walls in my Minuet, I had considered the possibility of a coat of paint. The original vinyl covering cleaned up beautifully and has been comparatively easy to maintain with a regular recoating with Future Acrylic floor wax. As such, I only have the instructions for painting -- my intent was to consult my local MAB paint store's personnel for their recommendations for primer and top coat.
My Overlander had experienced painting of its original Zolatone at some point in its life so it did require a freshing after I acquired it in 1995. With my coach's already painted over Zolatone, I chose to follow my local MAB retailer's suggestion and utilized an oil-based primer/sealer/surfacer (we knew that the existing paint was oil-based as a touch-up can had been left in the coach by the previous owner). The top coat was a three coat process that was applied utilizing a sponge-painting process to simulate the Zolatone.
Kevin
Kevin D. Allen
AIR #827
Steps on 1978 ARGOSY MH Octane Mechanics Corner - Engines, Transmission & More... 4 01-04-2012 04:31 PM
painting your argosy pavlova All Argosy Trailers 10 08-14-2011 03:58 PM
Need 1978 24' argosy bathroom sink dennis29 Sinks, Showers & Toilets 6 06-04-2011 06:56 PM
1978 airstream- argosy 24 trailer...NO RESERVE!!! eBay Watch Airstreams on eBay 0 05-29-2011 01:31 AM
1978 27' Argosy built by Airstream eBay Watch Airstreams on eBay 0 03-10-2011 06:40 PM
