Old 02-14-2016, 05:01 PM   #1
Satellite Beach , Florida
Painting all interior surfaces
We just purchased our first AS, a 1979 31' Sovereign this past week and are about to begin updating her. The interior surfaces are terribly sticky and yellowed, and we want to paint it all - walls and cabinets - white. The cabinets seem to be some sort of wood look veneer over plywood. The tall panel that runs floor to ceiling next to the fridge is peeling, as well as a few other places. The "wallpaper" int eh shower is also peeling at the top. I have read several threads on here regarding recommendations for different products to prep, prime and paint, but there doesn't seem to be any clear recommendation as most have painted over something existing or didn't have stellar results. Can anyone recommend a method and/or products that are tried and true? We plan to keep this AS for well over 15 years until we become empty nesters and want to make sure our finishes hold up - we want to do it right the first (and hopefully only) time.
The gentleman at Lowe's in the paint department recommended cleaning with TSP, priming with BIN, and then painting with whatever paint we wanted. I'm still nervous about the plastic surfaces though, especially the trim on the edges of the cabinets. I was thinking oil based paint, but want to confirm those recommendations with someone who's been there and done it before we start. Don't want any regrets.
Thanks in advance for all of your help. We're really excited about getting her updated and on the road - hopefully by the time school lets out for summer!
Sue
suzuz22 is offline   Reply With Quote
Old 02-14-2016, 06:32 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Where do I begin......
Painting your interior, especially the walls will be the first thing you will regret doing, as it will eventually start peeling and flaking off. The second thing you will regret, will be painting the interior walls or cabinetry as they too will begin to start peeling and flaking off.
Don't do it....period.
Take out the interior as much as possible and clean up the walls with Spray Nine. You would be surprised at how much gook and crud Spray Nine will get off. Then evaluate the results. If you still are unsatisfied with the results, may I suggest a 3M Dii-noc Weave vinyl sheeting to be applied by a proffesional to the interior.
As for the cabinetry, you could strip and repaint but you may find it easier to take the cabinetry to a local woodworking and ask them to replace it with a Dominoed face frame cabinetry that would be painted properly with a durable catalyzed laquer.
I used the 3M Weave on most interior surfaces other than the walls and built my own cabinets.
Before pictures of my 310's interior.
http://www.viewrvs.com/motorhome/air...1983_310_k.php
After pictures.
http://www.airforums.com/forums/f311...s-97332-4.html
Cheers
Tony
Old 02-14-2016, 06:41 PM   #3
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
We painted the interior of our safari several years ago. We used TSP, a good bonding primer, and a good latex paint.
This was at least 5 years ago. The finish shows absolutely no signs of flaking, chalking, or deterioration.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 02-14-2016, 07:06 PM   #4
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
We painted almost everything white in our '77 Overlander with either Krylon Fusion for plastics or an AceHardware brand primer and paint 2 years ago. It adhered wonderfully and we are happy as can be with it. Not a single regret. We camped in it 100 nights the first year so it has seen some heavy use. It feels wonderful inside! We have a '97 Excella we wouldn't consider doing that to as it is just a different animal.
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Paddledipper is offline   Reply With Quote
Old 02-14-2016, 07:12 PM   #5
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Its all in the prep as to how it will turn out. All the light blue that you see in ours had the dark walnut vinyl on them.
ID:	257278   Click image for larger version
Name:	trailers pictures 176.jpg
thehandyman is offline   Reply With Quote
Old 02-14-2016, 07:19 PM   #6
penticton , British Columbia
After pictures.
Cheers
Tony
I will disagree with this
Do it properly. clean the surface...use the expensive but bulletproof BIN primer...and you will never see peeling ever. it s one of the best way to refresh the interior....make it look clean and nice. Krylon fusion for the plastic surface is another very simple and effective way to refresh the inside.
I done this with many trailers.... no issue so far... never regretted it!
jonnyo is offline   Reply With Quote
Old 02-14-2016, 08:01 PM   #7
1977 27' Overlander
1996 34' Excella
Name:   ImageUploadedByAirstream Forums1455505182.633567.jpg
Name:	ImageUploadedByAirstream Forums1455505205.477425.jpg
ID:	257286Click image for larger version
Name:	ImageUploadedByAirstream Forums1455505226.194390.jpg
ID:	257287Click image for larger version
Name:	ImageUploadedByAirstream Forums1455505246.693961.jpg
I've shared these many times before but I LOVE it so much I'll do it again. 😍
The Evans' Family
Florida Panhandle
Old 02-14-2016, 08:08 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If the surface is prepped properly, it will not peel.
I would sand as well as clean.
I didn't mention that above.
Brevi tempore!
Old 02-14-2016, 08:10 PM   #9
Paddledipper, thanks so much for the photos! I've seen your photos several times on here and always are drawn to them - love the white and the bright colors. I do believe I have your photos on my Pinterest board!
Do you mind elaborating on what you used the Krylon Fusion for and what you used the Ace primer & paint for? Also, what did you do to prep the surfaces? And was the Ace paint oil based or latex? Thanks so much!
Old 02-14-2016, 09:38 PM   #10
1977 27' Overlander
1996 34' Excella
Cleaned lightly with Clorox Clean Up. I didn't have any of the sticky residue so many others have dealt with. Krylon for end caps, all the bathroom surfaces including the countertop, tub and shower stall and all tambor doors. Click image for larger version
Name:	ImageUploadedByAirstream Forums1455510905.074892.jpg
Name:	ImageUploadedByAirstream Forums1455511091.460258.jpg
ID:	257294. Pinterest, really? Neat!
The Evans' Family
Florida Panhandle
Old 02-16-2016, 08:28 AM   #11
Kathys quilt's Avatar
1967 30' Sovereign
Nauvoo , Alabama
Does Painting the inside, even with the best. take away value?
To all who served - give them thanks - give them respect - may God give all many blessings (Ray Bozeman)
Kathys quilt is offline   Reply With Quote
Old 02-16-2016, 07:01 PM   #12
1979 25' Tradewind
Myrtle Beach , South Carolina
we decided to strip all the vinyl off which left a really nice aluminum finish which looks like the brand new airstreams. See my youtube video on this "Airstream, How to remove vinyl from the interior walls".
Corey H is offline   Reply With Quote
Old 02-16-2016, 08:34 PM   #13
KYAirstream's Avatar
Northeastern , Kentucky
Originally Posted by Paddledipper View Post
Cleaned lightly with Clorox Clean Up. I didn't have any of the sticky residue so many others have dealt with. Krylon for end caps, all the bathroom surfaces including the countertop, tub and shower stall and all tambor doors. Attachment 257293
Attachment 257294. Pinterest, really? Neat!
So the krylon works for the tub and sink too? How many years has the Krylon been applied to these areas? Did you lightly sand these areas first?
KYAirstream is offline   Reply With Quote
Old 02-17-2016, 07:32 AM   #14
1977 27' Overlander
1996 34' Excella
It has been on for 2 years now with an average of 75-100 nights and almost double that number of showers. I lightly sanded I'm sure I could have done a better job sanding, cleaning after sanding and I could have applied a thicker coat of paint but it was my first experience and do consider it a success. The Krylon melds onto the existing surface like it is one in the same. There are some spots on the edge of the counter where we brush as we pass by and bottom of the tub where it is rubbing thin but another sanding and spray should cover those spots when the time comes. They're not bad enough to worry about yet. The way that spray paint covers the tambor doors was probably the most surprising and pleasing part of all. I used the Krylon Fusion for Plastics in another color on an over bed light cover and that has worked well also. I certainly am no paint expert and this has all been just a fun hobby for us but we've had excellent experience with the Krylon for Fusion for Plastic and have seen many other success stories as well! Love to see pictures of other's experiences.
The Evans' Family
Florida Panhandle
Painting all interior surfaces suzuz22 General Appliance Topics 3 12-20-2017 10:43 AM
Aluminum sheet for interior surfaces drboyd Upholstery, Blinds, Walls & Interior Finishes 8 10-07-2012 06:49 PM
Painting all the sides of a new floor? supergg Repairing/Replacing Floor &/or Frame 11 10-10-2011 12:45 PM
Just finished painting, now have spots all over after drying?? dgreen78 Upholstery, Blinds, Walls & Interior Finishes 16 09-05-2011 07:05 PM
Mosaic Tiles on vertical surfaces? Blu_Hwy_Lady General Interior Topics 10 10-30-2006 06:24 PM
