Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 11-02-2004, 10:29 AM   #1
dmadam
Profile:  1983 34' Limited
Henderson , Nevada
Paintin walls
I am painting over the vinyl clad walls and have looked throught some past threads and got some good info but still need some feedback.
Just finished talking to a tech rep at Kilz. They sugested using the original Kilz and then using house latex paint. Or using the Premium Kilz and then the Rust Cap (I like the silver gray). Any one use the Rust cap and any sugestions?
They did back up Andy and say to scruff up the viny.
Thanks All
David
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 11-02-2004, 02:13 PM   #2
absent air
Profile:
Painting Vinyl ?
Hello, I have 26 years in the painting trade with much involved in painting old vinyl wall coverings. I have had great success with a product called Aqualock. Go to thier website insl-x.com This is a waterborn product that I have used for the last 4 years for it's adhesion as well as sealing properties. I am sure there are many products out there that will work, but I strongly recommend this one. I know it will stick much better than Kilz, wich I still use for other applications. Your main concern is it sticking to the vinyl.
Of course cleaning the surface is the most important step in the process.
Best of luck, Jesse
absent air is offline   Reply With Quote
Old 11-02-2004, 05:55 PM   #3
dmadam
Henderson , Nevada
One think I forgot tomention is the Masterchem tech was concerned about the rust cap hammered is that is dries solid and is non flexible and wondered that it might crack in a RV.
I saw in old threads that some have used it and wondered if that had been a problem
Old 07-09-2005, 04:48 PM   #4
solitairenc
Profile:
Where did you buy the Aqualock at? I went to their website and found no info on buying.
solitairenc is offline   Reply With Quote
Old 07-26-2005, 04:30 PM   #5
mello mike
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 22
I used a water-based indoor house paint. Worked
great though I needed two coats.
2003 Ford Excursion (6.0L PSD)
Prodigy / Equal-i-zer / Honda EU2000i / Xantrex Link 10
U.S. Navy (Retired)
Airstream Life Contributor
Air#5661 / WBCCI#--
My Refurb Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-26-2005, 05:25 PM   #6
jaiman
jaiman's Avatar
Profile:
Images: 32
I just finished painting the entire interior on my MH. As a plastics finishing technical sales rep I did a great deal of testing with various coatings. For safety I wanted to use a 100% water reducible system. I would caution anyone from using alkyd (oil) based primers as they tend to dry out over time. The system I finally used was from Sherwin Williams. The products are not available from the house paint stores but from the Chemical Coatings division and must be sprayed. I tried many types of cleaners but found the only way to remove the stickiness was to use a strong solvent. Laquer thinner. Stubborn areas were hit with some acetone. Alcohol might also work. Use many rags so not to contaminate clean areas. I then used a scotch brite pad to knock the sheen off the woodgrain vinyl clad aluminum. This vinyl clad presented the greatest adhesion challenge. I then applied by spray a coat of bonding primer for plastics.(only to the wood grain vinyl clad aluminum) Areas that need filling were coated with a coat of water reducible sprayfil and sanded. I allowed that to dry for an hour then applied a coat of Polane 700T. This is a texturable single component water based urethane designed for the plastics and electronics industry. It also, has to be sprayed. I like the look of the light texture so I then textured over the top. I will have pictures up shortly for those who are interested to review. I took my time testing and did many sample areas using various potential systems and found the best results were with the aforementioned system. I had painted the headliner a couple of years ago and have no signs of failure. This finish is hard and stain resistant. I can post technical data pages on the products to those who are interested. Alot of work but does it ever look good. No more bedroom dungeon from that hidious fake brown vinyl.
jaiman is offline   Reply With Quote
Old 07-31-2005, 12:05 AM   #7
jsmith351
Profile:  1976 31' Sovereign
1961 19' Globetrotter
Phoenix , Arizona
Sherwin Williams
Sounds like a great process. What are the color options?
jsmith351 is offline   Reply With Quote
Old 07-31-2005, 09:23 AM   #8
jaiman
jaiman's Avatar
Profile:
Images: 32
Unlimited custom colors.
Old 08-01-2005, 07:40 PM   #9
Globie64
Globie64's Avatar
Profile:  1964 19' Globetrotter
The Sea Ranch , California
interior finish product
I was looking for someting to replicate the zolatone interior in my '64, textured but a little cleaner and updated. Did you spray over Zolatone as well as the vinyl? What kind of sprayer did you use?
Sounds great..
Peter
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 08-02-2005, 07:21 AM   #10
jaiman
jaiman's Avatar
Profile:
Images: 32
I sprayed over everything. There appeared to be 3 different substrates. The head liner appeared to have been coated with something. Possibly Zolatone. I noticed that if I rubbed hard enough with the Laquer thinner during cleanup the color there would come off. IN any event it took my new paint very well with no signs of incompatibility or adhesion issues. I used a 2 quart pressure pot with a conventional spray gun.
Good luck.
Old 08-16-2005, 11:35 PM   #11
jsmith351
Phoenix , Arizona
Ever painted over the end cap in the bathroom? I have a couple of 4" cracks in mine, I was thinking about fiberglass patches over the cracks then heavy coats of paint. If it turned out looking like Doo Doo, then I would rip out the end cap and use the metal flashing technique.....
Old 08-24-2005, 06:28 AM   #12
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
Years ago I worked in a paint store and we sold a product called "Goof Off" which removed latex paint. I got to thinking if that paint sticks so good to virtualy anything it needs its own remover it must be pretty good. So I started using a good quality latex paint on virtualy everything including my Airstreams. True to its nature it sticks and sticks and sticks even where I drip and then have to get the "Goof Off." Preparation of course is needed and TSP plus elbow grease works well. Lightly scuff up the surface, patch the holes with plain old wood filler and sand smooth, then use a brush and medium nap roller, the results are stunning. Your color choice is limited to the store where you shop, I like my local True Value hardware store.
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://www.fuzzytravel.com/grandakent/
Chaplain Kent is offline   Reply With Quote
Old 08-24-2005, 10:24 AM   #13
jsmith351
Phoenix , Arizona
Wood filler on plastic? Hey I'll try anything once, but maybe Bondo would be a better chioce? Thanks for the suggestion, I'll try this first.
Old 08-24-2005, 12:14 PM   #14
tin sista
We can tow it!
tin sista's Avatar
Profile:  1996 28' Excella
Where the water tastes like wine , Michigan
Images: 82
Post Very helpful thread thanks!
Thanks all for posting this information--great food for thought...I'm adding some things to our to do list...
Steph in MI Air# 6996-
I Hockeytown USA!!
tin sista is offline   Reply With Quote
Zolatone walls Rob Upholstery, Blinds, Walls & Interior Finishes 18 02-06-2007 07:41 PM
interior walls happier General Interior Topics 7 07-02-2005 01:04 AM
removing interior walls: bad idea? pinkflamingoes General Interior Topics 45 07-14-2004 08:18 AM
Thick or thin walls? malconium Interior Restoration Forum 9 05-28-2004 02:43 PM
Do the 1978 Tradewinds have Vinylclad walls? tiniree Upholstery, Blinds, Walls & Interior Finishes 2 04-23-2003 11:18 AM
