Old 03-20-2010, 02:10 PM   #57
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
The issue does not seem to be finding a workable primer. There are a number of folks who seem to have used a range of products with some success, i.e., XIM, Kilz, etc. The issue is plasticizer migrating through the primer and paint to make the walls sticky. If you use the exoxy primer, let us know if you have any subsequent issues with "sticky walls."
hampstead38 is offline   Reply With Quote
Old 03-22-2010, 11:54 AM   #58
1963 24' Tradewind
San Diego , California
Originally Posted by Jim & Susan View Post
Just to update, my walls are still in good shape. I'm really surprised this worked. If I ever have to do this again, I'll probably try the oil based paint route.
I have painted over vinyl wallpaper many times, always using an oil base primer, it works! As stated from Jim & Susan above "If I ever do this again, I'll probably try the oil based paint route". You can put any paint over an oil base primer, as for me I would ONLY use an oil based enamel in my trailer, period, that's just me!
Looks better! Feels better! Last longer!
Sixty3TW4US is offline   Reply With Quote
Old 04-29-2010, 08:52 AM   #59
1972 25' Tradewind
Summerfield , North Carolina
Ever get that response from Dwight?
Hi Jim,
Did Dwight ever give you a brand name in response to your post on 8/25/2009?
Dwight's quote:
"I am a retired plastics engineer and have formulated many flexible PVC compounds. This sticky problem is common to many non-rigid PVC compounds. It is caused by the liquid plastiziers, that are used to make the PVC flexible, becoming incompatible with the rest of the PVC compound and being kicked out of solution or what we call "spewing". The degraded liquid plasticizers bleed to the surface of the PVC and then migrate into or combine with the top coat you have put on to cover up the problem. To be successful in the long run, you need to pick a top coat that is completely impermeable to the plasticizers. Otherwise, you will just cover up the problem till the plasticizers destroys the topcoat polymer. The underlying problem is the stabilizers in the plasticizers break down over time and the plasticizers degrade. You can not do much about that."
Your quote:
"Dwight, can you recommend something? Name brand, I mean.
Jim "
I'm trying to figure out the "correct" primer for my interior walls on my 1974 Trade Wind. I'm also trying to figure out whether or not to apply latex paint over the "correct" primer for my "spewing" flexible pvc interior walls.
Boy, I'd sure appreciate any enlightenment you might have on this sticky matter! Feel free to email me at: tojunk@att.net if you like (or anyone else reading this post). Thanks.
Daniel
todanielm is offline   Reply With Quote
Old 04-29-2010, 01:35 PM   #60
1967 26' Overlander
Upperco , Maryland
http://www.airforums.com/forums/f39/...ors-62392.html
This is what I have learned. I did the following: Pre-primed with XIM plastic primer, primed with Xinsser oil-based primer and painted with latex. I'll put a coat of Polycrilic on next.
Old 04-29-2010, 04:23 PM   #61
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Originally Posted by todanielm View Post
Hi Jim,
Did Dwight ever give you a brand name in response to your post on 8/25/2009?......
Daniel
No, Dwight never did answer that question.
Take a look thru my http://www.airforums.com/forums/f226...nte-15132.html thread and you can see how I did it. Use the search feature in the thread so you don't have to wade thru it all.
There are several members here ( I found after painting with the SW products) that used oil based primers and paints with good results. You might send them a PM after you locate their posts and ask specifics. From what I've read, Oil based coatings looks like a much better idea, from a longevity standpoint.
www.nesa.org
Air No. 6427
Old 11-02-2010, 07:32 PM   #62
Airstream Fanatic
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck , North Dakota
So does this mean if we keep the Albatross in the frozen northland, our paint job will be safe?
ND10CentCan is offline   Reply With Quote
Old 11-03-2010, 01:29 AM   #63
funkill's Avatar
reno , NV
Images: 27
I don't recall seeing anything mentioning the *sticky wall* issue is a factor on the local of the trailer ... but certainly post your results - whatever they may be! My walls are still sticky in areas not covered with polycrylic. But those that were are tack-free! Yay.
Laura
funkill is offline   Reply With Quote
Old 11-03-2010, 04:34 AM   #64
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
My long term testing of flexible PVC formulations, similar to the formulations used for the laminate covering on the inside of 1970 and 1980's Airstream Trailers. was done for medical grade PVC formulations and not targeted to trailers. In my testing spewing was a function of long term heat ageing. Long term storage at higher temperatures cause greater degradation and spewing. My testing was conducted to help me formulate improved PVC formulations to minimize the spewing. I did no testing of coating systems to cover up the problem. AT Johnson/Evinrude Outboard motor Co, I did testing for paint durability, but did not have any applications where we had to contend with spewing PVC formulations.
Old 11-03-2010, 01:21 PM   #65
Got gandkids?
Like Laura, I've had good results with the poly top coat. It's been over a year now and still no sticky coming back thru the top-coat poly. The entire interior was top-coated over a year ago.
Again, tho, it was a difficult process. If I had to do it over again, I'd go with oil based paints. YMMV.
www.nesa.org
Air No. 6427
Old 11-04-2010, 06:57 AM   #66
funkill's Avatar
reno , NV
Images: 27
My tackiness appeared within a few months - after one of our coldest winters.
But, if the tackiness (spewing?) is greatly affected by heat and time, I am skrewed! Well, unless I get that job in Wyoming, and quickly!
Laura
Ephemera - tacky or terriffic? Janet H Off Topic Forum 30 11-15-2008 10:39 PM
Red numbers paint? hand paint? Zstream Clearcoat, Exterior Paint & Trim 2 10-02-2008 11:35 AM
Tacky lights at Menards... Auretrvr Lights - Interior & Exterior 23 01-21-2007 06:09 PM
Paint stovetop with high temp paint? ironfem200 Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
Awning options - tacky, bland, poor taste? Janet H Awnings 11 10-05-2004 10:59 AM
