Old 06-26-2004, 03:58 PM   #1
Question Paint removal
I just got a 1972 31 footer and the PO had painted the interior walls with latex paint. Doe's anyone know of a paint remover that is safe for the vinyl covering on the walls?
any help would be....ah.....most helpful!
joecj76 is offline   Reply With Quote
Old 06-26-2004, 06:11 PM   #2
RichardT's Avatar
I belive any paint remover would disurb the vinyl covering as well as the paint.
I would experiment in a small test area before proceding, you might try a small test with some other products such as paint thinner or acetone but no matter what you decide to do, turn off all pilots and open all windows if using a flammable.
R
RichardT is offline   Reply With Quote
Old 06-26-2004, 09:35 PM   #3
gregg's Avatar
try some acetone. it will dissolve the latex and won't harm the wall covering-it's very flamable and volatile so be careful-use a couple big fans with all the windows open to exhaust the fumes and remember like everything, it is known to cause cancer. Don't plan on doing more than 1 sq ft at a time until you develop a feel for it.
gregg is offline   Reply With Quote
Plastic beads for clearcoat removal? john hd Cleaning, Stripping & Polishing 23 10-21-2011 11:25 AM
Interior Paint Lone Ranger Upholstery, Blinds, Walls & Interior Finishes 8 05-02-2004 10:34 PM
Exterior paint removal? SCBrat Clearcoat, Exterior Paint & Trim 9 02-06-2004 04:28 PM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 07:03 AM
