Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 03-21-2016, 12:48 PM   #1
1962 22' Flying Cloud
Alpine , Texas
paint prep/lead base paints used?
I am restoring a '62 Flying Cloud, changing the use. Was there any lead based used on the original factory interior? I am scraping to clean up, before I steel wool, sand a bit before spraying/paint. Any suggestions for a novice for paint prep?
DE101 is offline   Reply With Quote
Old 09-18-2020, 07:56 AM   #2
1973 Argosy 26
Oak Point , TX
Reviving this old question because I'm wondering the same. Although with the number of people using marine paint, I'm not sure heavy metals are a top concern for many here ��
antcant01 is offline   Reply With Quote
Old 09-18-2020, 09:15 AM   #3
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
1962 trailers had Zolatone paint - it's an automotive epoxy paint still available today. It's not lead based.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-18-2020, 10:36 AM   #4
Rot-Roo Rastro!!
silversled's Avatar
2020 30' Flying Cloud
I suggest you get a lead check test. Think you can get them online or at a hardware store. You can also collect a sample and send to an analytical lab. Pretty cheap (likely $40 or so). It is best to check before you work spreads it all over your trailer, your clothes (where you can spread it to your house and children) or your tools. Oh and don't forget they did install asbestos at one point or another.
Andrea
Barry & Andrea
2020 Flying Cloud 30' ~ Silversled
2019 Chevy HD2500, 4X4, Crew Cab
AIR #12075
silversled is offline   Reply With Quote
Low VOC Paints Further99 General Repair Forum 8 11-19-2010 11:13 AM
Paint prep and methods Dan S All Argosy Trailers 3 06-27-2010 09:46 PM
Spray on chrome style paints ob1coby Clearcoat, Exterior Paint & Trim 14 04-19-2007 06:16 AM
Automotive paints; advice please SmokelessJoe Clearcoat, Exterior Paint & Trim 5 03-18-2007 02:16 PM
70's AS asphalt-based frame paint prep for POR-15 Wabbiteer Repairing/Replacing Floor &/or Frame 1 10-09-2006 08:23 AM
