Old 07-29-2014, 08:40 PM   #1
1975 29' Ambassador
Fort Wayne , Indiana
Paint for Walls
I am stripping the contact paper off the bedroom back walls. This will leave the wood paneling surface. If I decide to paint the walls - what type of paint will work that will not crack for the normal movement of traveling with the trailer - Again thanks
tweetie1966 is offline   Reply With Quote
Old 07-29-2014, 10:19 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If i were to use a spray paint it would be a lacquer.
Whatever you use it will stick better if you give the surface a good sanding. If it is in fact wood I would recommend about 180 grit.
If you want to brush or roll I would recommend a good exterior house paint,,,, If it was my trailer I might use industrial Imron, but I know that this isn't for everyone.
Old 07-30-2014, 08:01 AM   #3
kootenayken's Avatar
1976 Argosy 22
cranbrook , British Columbia
When you strip off that contact paper there is usually a good coat of adhesive left. It has become brittle and can be sanded down, rather that using a adhesive remover that will turn it to goo. Then a couple coats of a good primer like STIX, this will seal your surface to make sure that the old adhesive will not bleed through to the new paint. I use Benjamin Moore Allure an exterior vinyl paint, durable, flexible and rolls out very nice.
kootenayken is offline   Reply With Quote
paint interior walls? ryan3326 Upholstery, Blinds, Walls & Interior Finishes 3 08-27-2009 07:32 AM
Interior Walls - Paint and Primers LI Pets Upholstery, Blinds, Walls & Interior Finishes 45 07-12-2009 02:44 PM
stripping paint from original vinyl interior walls Beverly II Upholstery, Blinds, Walls & Interior Finishes 1 10-10-2008 05:37 PM
Removal of Zolatone Paint from Interior Walls of '54 Wanderer rek Upholstery, Blinds, Walls & Interior Finishes 16 10-30-2007 04:38 PM
Paint for Shower walls? myboyburt Sinks, Showers & Toilets 4 04-28-2005 07:54 PM
