Old 03-07-2004, 09:33 PM   #1
Joe Z's Avatar
Rivet Padded fabric on the walls (rear bedroom)
I have a 1987 29' Sovereign w/ twin beds. On the walls running the length of each bed their is a strip of padded fabric about 1' tall X 8.5' long. I removed it and found that it is actually just some type of paper/cardboard that has foam and fabric sewn to it.
My question is....has anybody replaced these pieces before and if so what did they use? I like the padding beside the beds but the old fabric just does not match the new curtains so they've got to go.
If anyone has pictures of a remodel they've done or advice on what material to use instead of the cardboard/foam/material I'd appreciate it.
Thank you,
Joe
Joe Z is offline   Reply With Quote
Old 03-07-2004, 09:55 PM   #2
The reason for the padded, upholstered cardboard is that it needs to be very lightweight to attach easily to the compound curves and the back.
We used a very heavy, but short napped carpet remnant. I cut it, then had the edges bound. You will need a pattern as any carpet will need a "V" cut at the rear corner to make the turn. If you start with the upper edge cut on a straight line, this will, in turn, cause the upper edge to head downhill. Try it first with a paper patten and you will see what I mean.
You can, of course, upholster another piece of cardboard - it really is a very rational solution to a tricky fitting problem.
Mark
Old 03-08-2004, 04:59 AM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
When we redid the MH I reused the padded pieces. All I did was cover over the existing fabric and cardboard with some polyfelt and then some of the matching fabric we were using. I used contact cement spray glue to hold it all in place. The screws to hold it to the wall mechanically fasten it all together. I have done it that way in 2 coaches so far and it has worked well.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 03-08-2004, 05:49 AM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Me too
I recovered the original pieces.
You can duplicate pattern without "Notches". The cardboard is not Square, it is shaped with a slight curve. If you lay it flat , you will see what I mean.
You can see it below:
smily is offline   Reply With Quote
Old 03-08-2004, 08:36 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Ours shares the same vinyl/leather like material that covers my barrel chairs and other trim now.
Gave the bedroom area a more modern look than the old 80's fabric.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-08-2004, 08:54 AM   #6
ke4pk's Avatar
Images: 8
Talking
WE REPLACED SOME OF THAT SAME TYPE WALL COVERING ON A 1981 EXCELLA AND WE USED A SHORT PILE COMMERCIAL GRADE CARPET....WORKED GREAT!
ke4pk is offline   Reply With Quote
