Old 07-23-2016, 07:56 AM   #1
1998 25' Safari
Ballard , West Virginia
Oh That Smell
We have just acquired a 1998 Safari. It has set for many years and the only thing living in it was "mice". We have stripped the carpet out, scrubbed from head to toe....several times. It has the white "mouse hair" on the wall (ironic huh)....lol. My problem is: I can't seem to get that smell out of it. When it is hot and dry....I think we've done it....then as soon as a rain comes and the humidy sets in.....eeewwww. Anyone out there have a solution? We have tried carpet cleaner.....then really good carpet cleaner....then Clorox solution.... fans...... I'm getting desperate. Thanks
CADUNN is offline   Reply With Quote
Old 07-23-2016, 08:08 AM   #2
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
If you have mid twins pull them up and clean the area underneath of them. We were shocked at the nests that had been built under ours. The wheel well area seemed to be their favorite spot.
1973Argosy is offline   Reply With Quote
Old 07-23-2016, 08:21 AM   #3
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
My nonexpert guess is that your trailer leaks. Big clue: when it rains and humidity increases the odor returns. To completely rid yourself of that odor, you are probably going to have to open up walls and the floor to get to nests and excrement, and replace insulation that is / was infested.
Good luck!
Susan
duncans is offline   Reply With Quote
Old 07-23-2016, 08:37 AM   #4
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
Good luck!
Susan
Be careful cleaning the mess from mice and rats. Their urine can carry deadly diseases. Wear rubber gloves, wear an antiseptic face mask, and above all don't touch around your eyes. This is serious stuff. We had a friend cleaning out a basement after her father died. See came down with an almost undiagnosable disease. Only when the CDC in Atlanta got involved was it diagnosed. She nearly died. She lost part of her vision.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 07-23-2016, 11:33 AM   #5
1998 25' Safari
Unhappy
Good luck!
Susan
Thanks for the response....I'm hoping....but I fear you could be right!
Old 07-23-2016, 11:48 AM   #6
Central , Mississippi
A friend had the same problem. He solved it with a commercial ozone generator over night AND got the leaks fixed. A pressure test located all of the leak points. It only takes a small amount of water to reactivate the stink. He has been dry and smell free ever since.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-05-2017, 08:54 AM   #7
1977 31' Excella 500
Red Rock , Texas
The ozone generators mentioned above are highly effective in this situation. I have a $79 model purchased from amazon that has done amazing things in closets, airstreams, refrigerators, conex boxes and vehicles. I used it in a conex box that had been infested with rats. It was nothing short of miraculous. It removed the stink from a fridge full of meat and cheese that was unplugged for a month. truly amazing...
junkyardawg is offline   Reply With Quote
Old 04-05-2017, 09:19 AM   #8
Wichita , Kansas
I'm going with the leak theory too. My 74 has a bitter smell because of wet plywood. The only solution is repair the leak and seal or replace the floor. At least that's what I'm going to try. Good luck to both of us!
nhisservice is offline   Reply With Quote
Old 04-05-2017, 09:19 AM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have seen many posts about mice nesting in the belly pan.
My 71 was a mouse condo. A good cleaning helped, but a residual smell was still there. After 5 years or so there is no smell, or maybe I just got used to it.
Old 04-05-2017, 09:27 AM   #10
1973 23' Safari
1970 27' Overlander
Boerne , Texas
When we took our inside walls out as well as the belly pan, the smell from the insulation was overwhelming. But I know that is whole another layer of complexity.
Greg
Greg1410 is offline   Reply With Quote
Old 04-05-2017, 09:42 AM   #11
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Mice get in between the walls and the belly pan area and make nests in the insulation. The only way to get rid of the smell is to gut the trailer and remove the inside walls and belly pan, clean everything very well, let it dry, re insulate and reinstall the interior walls. Anything short of this will lead to disappointments down the road.
Bob Martel
WBCCI# 5766
Old 04-05-2017, 09:49 AM   #12
1976 31' Sovereign
Oswego , Illinois
The mission band came loose from black water dump valve letting sewage flow into belly pan. [mission band is rubber coupling with hose clamps each end AS has other name]. Will ozone generator remove smell from inside AS? Right now I cannot smell any odors but not hot outside. This happened last Oct. sure don't want crappy smell this summer. Bill
Old 04-05-2017, 10:29 AM   #13
1994 28' Excella
Burkburnett , Texas
One person said that after removing the headliner the barn yard smell went away.
paulken is offline   Reply With Quote
Old 04-05-2017, 08:32 PM   #14
Lumatic's Avatar
1993 34' Excella
Images: 16
Mouse Mummy
Sewer Gas Smell davespann Waste Systems, Tanks & Totes 18 07-24-2016 08:57 PM
LP Gas smell when furnace first kicked on Impala SS Guy Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-30-2003 12:08 PM
Oil Smell George Mechanics Corner - Engines, Transmission & More... 0 09-02-2003 05:06 AM
Bad cabin smell from new Solar instalation w9det 2001 Safari 7 04-21-2003 10:21 AM
Furnace exhaust smell Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-25-2003 07:54 PM
