Old 06-24-2008, 05:36 PM   #1
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
New Partitions - What's the best technique?
I'm working on cabinets and new interior partitions and I had a general question about what is the best technique to copy the shape of the interior shell to create panels.
Is the stick trick or magic stick the best way?
Doug
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 06-24-2008, 05:53 PM   #2
Images: 59
Ah yes. Unless you have a laser profiler, the storystick is the way to go!
Old 06-24-2008, 07:14 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Ahh Don, you are a man of discerning taste and discriminating intellect!
Doug, with the story stick technique you can get close enough to do adjustments with small amounts of hand planing. It's just necessary to align a reference plane in line with what you want. The bigger the better - yes. If you can use a reference scrap half the size for scribing onto and keep it flat, that's all it takes. Just level your trailer first the more square and plumb you want to keep it -- but don't expect perfection from what originally came out of Jackson Center.
sharene showed some interesting work earlier today -- not sure how they did it though -- Beds & Bulkheads - Looking back to front First section will be a cutting station w/cabinets for storage underneath. Photo Gallery
5 meter Langford Nahanni
Old 06-25-2008, 03:59 AM   #4
1956 22' Caravanner
Laser Scribe?
Thanks. I need to make five of these panels and I have the original aluminum channel set aside. In the picture you referenced, what type of aluminum channel is that used to hold the panel to the wall?
Laser Scribe? Sounds interesting where would you get one
having trouble with my cyclo technique greenrig Cleaning, Stripping & Polishing 21 04-09-2008 10:33 AM
Final Floor Replacement Technique JohnG Repairing/Replacing Floor &/or Frame 46 01-15-2006 03:43 PM
Body and banana wrap on floor replacement technique. malconium Repairing/Replacing Floor &/or Frame 56 09-09-2005 09:09 PM
Attaching interior partitions to the walls? malconium Cabinets, Counter Tops & Furnishings 13 08-16-2005 06:38 PM
Questions on riveting technique 74Tradewind Ribs, Skins & Rivets 6 05-24-2002 09:45 PM
