Old 09-11-2017, 11:23 AM   #1
Peterborough , New Hampshire
New interiors wall ideas
We would like to hear what materials people have used to replace their interior walls? We are doing a complete renovation to the frame. The old walls have some cracks and we would just like to start new. What did you use?
terricrowe26 is offline   Reply With Quote
Old 09-11-2017, 11:40 AM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Pintrist is your friend.
Old 09-11-2017, 12:16 PM   #3
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
We used a woven vinyl from Chilewich to replace the mouse fur in our 2005 Safari. It's incredibly awesome, and my absolute favorite part of the renovation. It was also the most expensive part of the deal. For a 30' trailer, I think all-in it was close to 3K--which includes labor to remove the old stuff, prep, and install the new material.
DaveMc is offline   Reply With Quote
Old 09-11-2017, 02:06 PM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I used 5050 .040 thick aluminum for that shiny interior look. The PITA part of the project was finding a clear coat to put on it--didn't turn out as nice as I had hoped, especially for the cost and effort that went into it. The other mistake I made was not immediately removing every finger print I put on the panels as I installed them, and a month later when I went to do the clear coating, I had to sand out the (now permanent) prints.
good luck!
Old 09-11-2017, 02:11 PM   #5
1979 23' Safari
Wayland , New York
Just to clarify, you're talking about the wood partition walls vs the interior skins correct?
Old 09-11-2017, 06:15 PM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Your question may not be specific enough to gain insight. When you wrote 'walls' did you mean the skin material for the interior shell, structural material for partitions, or wall coverings? If you mean the aluminum interior skin, then replace the damaged sections with aluminum as that layer is specifically a part of the shell's structural strength. Apply whatever decorative layer you desire after that.
If you meant exposed/final layer, I removed the "mouse fur" and put up UtraLeather in the front section and a textured vinyl in the bedroom. Some use paint, cloth, vinyl or wall paper and I've seen thin plywood applied with spectacular affect. It all depends on the design theme/aesthetic you want to achieve.
UltraLeather finish:
http://www.airforums.com/forums/atta...2&d=1445358798
Wood Paneling over aluminum:
http://www.airforums.com/forums/atta...1&d=1183417292
http://www.airforums.com/forums/atta...2&d=1162254459
http://www.airforums.com/forums/atta...8&d=1284865775
Woven Grasscloth:
http://www.airforums.com/forums/atta...5&d=1301361018
Stickup Tiles:
http://www.airforums.com/forums/atta...9&d=1309898861
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 09-12-2017, 09:40 AM   #7
I am talking about the interior skins. I really don't want to strip them, I want to replace them with something else, or is it in our best interest structurally to reuse the aluminum interior skins by stripping and either painting or applying some other material to the alum. We are taking this trailer down to the frame. We have floor rot, we are taking out the black water tank and add a gray water and a composting toilet. Our AS didn't have a gray water tank. We will do all new plumbing and electric. We haven't decided if we want for a heating system yet. Our AS is only a single axle and 18' so space is hard to come by. How many people actually use the ovens? I could really use that room for just a cook top and have more storage.
Old 09-12-2017, 10:52 AM   #8
funkill's Avatar
reno , NV
Images: 27
Might be helpful to state the year and model of your Airstream for best feedback on stripping and structural integrity.
Mine were vinyl coated and painted. Some of us have had some issues with painting.
I've seen pics on this forum and on pinterest, et.al, of folks striping to bare aluminum, replacing with wood, covering with vinyl, etc. I also noticed the big bolts of the woven material (as used for some outdoor chairs and placemats) at a large, local fabric warehouse. I've considered using it to cover the (laminate) bulkheads in my trailer. Very cool colors, patterns and a modern look. I think it's similar to the Chilewich mentioned in a prior post.
Good luck!
Funkee
FunKee - and the Silver Olive
2006 F-150 Lariat QuadCrew
AIR 31804
WBCCI 10718
funkill is offline   Reply With Quote
Old 09-12-2017, 11:06 AM   #9
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Wood
In my 55 FC (now sold) I had the same issue- ugly painted skins that were hard to strip. I opted to cover them in clear-coated birch with aluminum trim. Also have yet to bake in any of the ovens in my AS's but they do make good storage spots for cookware.
Name:	Center aft end cap.jpg
ID:	294684   Click image for larger version
Name:	Roof vent paneled.jpg
BambiTex is offline   Reply With Quote
Old 09-12-2017, 11:24 AM   #10
2009 30' Classic
Crestview , Florida
Following
Looking for ideas too.
Paul & Holly is online now   Reply With Quote
Old 09-12-2017, 12:30 PM   #11
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
We're doing ours in wood. I like the look, but it's a lot of work!
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 09-12-2017, 01:52 PM   #12
1968 22' Safari
Shillington , Pennsylvania
I am looking at a thermal plastic that looks like aluminum called Fasade that is available at Lowes. It is used for home interiors such as back splashes, walls and ceilings . Very lightweight , does not scratch or dent, comes in many colors and textures to resemble copper, stainless steel and aluminum . Check it out. Fasadeideas.com
jimstream is offline   Reply With Quote
Old 09-12-2017, 02:31 PM   #13
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
We are using 1/8th-inch birch plywood on the inner walls, and we reattached the aluminum skins first. The alum was full of holes, the vinyl covering would not clean up, and the wood looks great. The birch is very light-weight. One 4'x8' sheet might weigh three or four pounds at the most. Much better-looking than the '70s plastic look. And arguably taking no more time than cleaning up the aluminum would have.
youngpeck is offline   Reply With Quote
Old 09-12-2017, 03:28 PM   #14
1979 23' Safari
Wayland , New York
18 feet long from where to where. If your trailer is only 18 feet long it should be pretty easy to replace the interior skins with new aluminum if you wanted to. I replaced all the interior aluminum on my 23' using the old skins as templates. It was pretty straight forward. I primed with etching primer before installing then rolled on exterior paint. Since I had them all removed it seemed easier and quicker than stripping the 70s vinyl. Plus they had lots of holes from bad PO repairs/use.
You can cover the old ones as well as mentioned by the beautiful posts by others above.
My original plan was to cover the new aluminum with wood veneer but time and money!
Need new wall panel ideas? minamyna Upholstery, Blinds, Walls & Interior Finishes 17 08-25-2015 09:21 AM
Inovative Ideas for Interiors TWaugh Cabinets, Counter Tops & Furnishings 13 11-28-2011 09:19 AM
Interiors of '05 and '06 Cedars Our Community 4 08-22-2005 08:46 AM
2004 Airstream Classic Interiors & Options Craftsman 2001 - 2005 Classic 3 04-30-2004 07:24 AM
Argosy interiors, 24' + darkStar All Argosy Trailers 1 08-01-2003 03:05 PM
