Old 08-15-2014, 02:10 PM   #1
tenrsingr's Avatar
Need to remove the forward interior endcap 1994 29ft Excella
Just purchased this and need to replace the forward flooring and wall covering(carpet). The endcap won't come off and I've removed all the visible rivets and screws. Click image for larger version
Steve_in_Savannah
'94. 29' Excella Classic
2001 5.4L Ford F150 Lariat Super Cab
wife & 2 boys
tenrsingr is offline   Reply With Quote
Old 08-15-2014, 03:27 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by tenrsingr View Post
Just purchased this and need to replace the forward flooring and wall covering(carpet). The endcap won't come off and I've removed all the visible rivets and screws. Attachment 219092
Why do you want to take it down and risk cracking it?
Its probably held up there by an abundance of vulkem used at the factory. You will find all kind of wires duck taped or glued to it, so be careful when you drop it down. 4 hands are better than 2
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-15-2014, 04:05 PM   #3
tenrsingr's Avatar
I'm trying to get carpet removed. And there is also a large dent in the roof from a pine tree limb. It also seemed like there was a rivet I tried sliding a scraping tool behind and it wouldn't slide due to something.
Steve_in_Savannah
wife & 2 boys
Old 09-10-2014, 10:30 AM   #4
tenrsingr's Avatar
Painting Endcap.
Removed and out. Does anyone have suggestions on painting? There was a crack in the curve due to PO and as i was trying to repair the crack it opened up. so I am going to use a fiberglass kit to reinforce the area and hopefully heal the crack. What to use for paint?
Steve_in_Savannah
wife & 2 boys
Old 09-10-2014, 11:40 AM   #5
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Can you describe a little of your process in removing the endcap? How did it go? Any unexpected problems? How many hands did you actually need to drop it safely? I'm about to take mine off. Your experience would be of interest to me and I'm sure many others. Thanks for the insight.
By the way, there are some other current threads about this exact issue you are dealing with--especially the painting.
youngpeck is offline   Reply With Quote
Old 09-10-2014, 12:00 PM   #6
1972 23' Safari
Camas , Washington
we painted our end cap after washing it with marine clean. Pam primed it with XIM and then a primer paint from Sherwin Williams, and after that the color coat. seems to be working so far.
I had a few small cracks I used some fiber glass tape on the back side and it seems to be working. Good luck with yours.
Pams72 is offline   Reply With Quote
Old 09-10-2014, 01:06 PM   #7
tenrsingr's Avatar
It would've came down better with two people, but I got it down by myself. Just have the area prepped ft a place to put it while disconnecting wiring that may be taped to it.
Steve_in_Savannah
wife & 2 boys
Old 09-15-2014, 07:50 AM   #8
tenrsingr's Avatar
Finished Painting yesterday.
Repaired cracks and reinforced prone cracking area with fiberglass bondo. Painted with rustolem paint for plastic from autozone. I'll post pictures later today.
Steve_in_Savannah
wife & 2 boys
Old 09-21-2014, 03:21 PM   #9
tenrsingr's Avatar
Installed R Max first layer. Wires mounted and strapped. Click image for larger version
Name:	ImageUploadedByAirstream Forums1411334507.198589.jpg
Steve_in_Savannah
wife & 2 boys
Old 09-21-2014, 03:36 PM   #10
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
From a recent conversation with Colin Hyde, I know that he often uses automotive paint on the restored and reinforced interior end caps.
Bob Martel
WBCCI# 5766
Old 09-21-2014, 03:43 PM   #11
tenrsingr's Avatar
I finished with Fiberglas bondo and painted with plastic coat from rust oleum. .
Steve_in_Savannah
wife & 2 boys
Old 09-21-2014, 04:15 PM   #12
Chelsea , Michigan
Images: 12
Sounds good. Please post a picture when you get it back in place. Thanks, Bob
Bob Martel
WBCCI# 5766
Old 09-21-2014, 04:17 PM   #13
tenrsingr's Avatar
Here it is in my garage. Click image for larger version
Name:	ImageUploadedByAirstream Forums1411337854.507863.jpg
Steve_in_Savannah
wife & 2 boys
Old 09-21-2014, 04:21 PM   #14
Chelsea , Michigan
Images: 12
Wow! Very nice indeed!
We helped to "deconstruct" a 1972 Overlander a couple of weeks ago with some friends at Colin Hyde's place in Plattsburgh NY in preparation for Colin's rebuild. I have to admit that I may have caught the restoration bug during that project!
Bob Martel
WBCCI# 5766
Interior endcap installation 2vets General Interior Topics 22 02-11-2014 01:07 PM
Interior Endcap Re-installation DanB General Interior Topics 14 04-10-2009 03:14 PM
Removing interior front endcap Mister Ed Ribs, Skins & Rivets 4 01-15-2009 09:17 PM
Interior Endcap Removal Proceedure? DanB General Interior Topics 2 08-17-2006 11:03 AM
Cracked Interior Endcap LuminumTraila General Interior Topics 9 03-03-2005 07:23 PM
