08-15-2014, 02:10 PM
Need to remove the forward interior endcap 1994 29ft Excella
Just purchased this and need to replace the forward flooring and wall covering(carpet). The endcap won't come off and I've removed all the visible rivets and screws.
Steve_in_Savannah
'94. 29' Excella Classic
2001 5.4L Ford F150 Lariat Super Cab
wife & 2 boys
08-15-2014, 03:27 PM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by tenrsingr
Just purchased this and need to replace the forward flooring and wall covering(carpet). The endcap won't come off and I've removed all the visible rivets and screws. Attachment 219092
Why do you want to take it down and risk cracking it?
Its probably held up there by an abundance of vulkem used at the factory. You will find all kind of wires duck taped or glued to it, so be careful when you drop it down. 4 hands are better than 2
AIR #13
08-15-2014, 04:05 PM
I'm trying to get carpet removed. And there is also a large dent in the roof from a pine tree limb. It also seemed like there was a rivet I tried sliding a scraping tool behind and it wouldn't slide due to something.
Steve_in_Savannah
wife & 2 boys
09-10-2014, 10:30 AM
Painting Endcap.
Removed and out. Does anyone have suggestions on painting? There was a crack in the curve due to PO and as i was trying to repair the crack it opened up. so I am going to use a fiberglass kit to reinforce the area and hopefully heal the crack. What to use for paint?
Steve_in_Savannah
wife & 2 boys
09-10-2014, 11:40 AM
1976 25' Caravanner
Salt Lake City
, Utah
Can you describe a little of your process in removing the endcap? How did it go? Any unexpected problems? How many hands did you actually need to drop it safely? I'm about to take mine off. Your experience would be of interest to me and I'm sure many others. Thanks for the insight.
By the way, there are some other current threads about this exact issue you are dealing with--especially the painting.
09-10-2014, 12:00 PM
1972 23' Safari
Camas
we painted our end cap after washing it with marine clean. Pam primed it with XIM and then a primer paint from Sherwin Williams, and after that the color coat. seems to be working so far.
I had a few small cracks I used some fiber glass tape on the back side and it seems to be working. Good luck with yours.
09-10-2014, 01:06 PM
It would've came down better with two people, but I got it down by myself. Just have the area prepped ft a place to put it while disconnecting wiring that may be taped to it.
Steve_in_Savannah
wife & 2 boys
09-15-2014, 07:50 AM
Finished Painting yesterday.
Repaired cracks and reinforced prone cracking area with fiberglass bondo. Painted with rustolem paint for plastic from autozone. I'll post pictures later today.
Steve_in_Savannah
wife & 2 boys
09-21-2014, 03:21 PM
Installed R Max first layer. Wires mounted and strapped.
Steve_in_Savannah
wife & 2 boys
09-21-2014, 03:36 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
From a recent conversation with Colin Hyde, I know that he often uses automotive paint on the restored and reinforced interior end caps.
Bob Martel
WBCCI# 5766
09-21-2014, 03:43 PM
I finished with Fiberglas bondo and painted with plastic coat from rust oleum. .
Steve_in_Savannah
wife & 2 boys
09-21-2014, 04:15 PM
Chelsea
, Michigan
Sounds good. Please post a picture when you get it back in place. Thanks, Bob
Bob Martel
WBCCI# 5766
09-21-2014, 04:17 PM
Here it is in my garage.
Steve_in_Savannah
wife & 2 boys
09-21-2014, 04:21 PM
Chelsea
, Michigan
Wow! Very nice indeed!
We helped to "deconstruct" a 1972 Overlander a couple of weeks ago with some friends at Colin Hyde's place in Plattsburgh NY in preparation for Colin's rebuild. I have to admit that I may have caught the restoration bug during that project!
Bob Martel
WBCCI# 5766
09-29-2014, 05:50 PM
Just putting last touches of reflective insulation and install end cap.
Steve_in_Savannah
wife & 2 boys
09-30-2014, 09:09 PM
Installed end cap. YIKES WHAT A PAIN. NOW I HAVE TO DO A REPAIR CRACK. Oh well. The bondo didn't hold so I'll use fiberglass this time. But the job is done.
Steve_in_Savannah
wife & 2 boys
