Old 07-20-2004, 10:25 AM   #1
Need pattern for original curtains
Does anybody have, or can you direct me to, a place to get a basic pattern for the original curtains (for 1971 Overlander, but I think they are pretty much the same)? I guess if I could get my hands on an old curtain that I could make a pattern out of, that would be okay.
Thanks, Rosie
roseyonnex is offline   Reply With Quote
Old 07-20-2004, 10:34 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I am replacing all my curtains with new ones from James Ambruse(sp?), and will be trashing the old, original ones soon.
If you think a curtain from a '67 Overlander would help your effort, drop me a personal message.
Tom
Old 07-20-2004, 12:00 PM   #3
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
Rosie,
I don't think there is a pattern, since all you are dealing with are big rectangles, made to the length and width of your window (it doesn't hurt to be a little generous with width). Generally they are pinch pleated at the top, sometimes at the bottom. Use curtain buckram to stiffen and make these pleats stand nicely. The biggest issue will be the hardware in your trailer--there are so many different kinds. In my (61), it had snaps--and I had a dickens of a time finding snap tape that fit the snaps on the carrier pieces. Since I had to hand sew in these snap tapes, using the nice pleater tape and hooks was not possible--I sewed in the pleats.
Here is my process:
Measure window space, divide width in half and calculate fabric requirements, considering 5.5" every 4" for pleats, 4.5" at top and bottom for top seam allowance and bottom hem, and 2" extra edge allowance on the sides for edges. Also--extra fabric has to be added if you have to seam two pieces together to get the width you want.
Heck, I'm on lunch break...Here are directions for top pleated curtains:
This works out as:
Fabric Width (per panel)
(Width of window/2)/4=Y
Y*5.5=extra fabric width for pleats.
Total Fabic Width=Width of Window + Extra Fabric width for pleats + 2" edge allowance (+ 1" seam allowance if sewing two pieces of fabric together to get sufficient width for the panel)
Length
Length of window +4.5" + any desired overhang
Step 1. Cut curtain fabric and lining to the same dimensions, except make the lining 1/2" shorter in length. Seam sides if necessary to get desired width.
Step 2. Lay the fabric down with the pretty side of the curtain fabric lying up. Put the lining fabric on top of it, so that the coated side faces up as well. Then unroll and place 4" curtain buckram at the top edge. Pin at the top. Seam the top edge. Fold the fashion fabric over the seam allowance (so it goes up and over the buckram and lining fabrics). Press.
Step 3. Measure the length and mark the desired hem point on both fashion and lining fabric (lining should be 1/4" shorter). Fold hems and stitch in place.
Step 4. Pin pleats in place. This is easiest started from the center--if you have an odd number of pleat bunches, then the center pleat is there, if even, measure 2" from the center point. Each bunch is 3 pleats. Hint--place pleats on both panels at the same time, so you can make them match. Press pleats in place.
Step 5. Sew bar tacks 4" from the top on each pleat set to hold in place. Hand tack the backs of pleats in place at the top of the curtain (this is a fine detail I'll probably have to photograph later for it to make sense, but it make it look much crisper). Attach carrier mechanism appropriate to your trailer.
Step 6. Test in trailer. Decide if you want to cut edges. Sew edges closed.
Ones with bottom and top pleats are almost the same, except you will sew the curtain and lining fabrics into a big tube, inserting top and bottom lengths of curtain buckram. Then do pleats at the top and bottom at the same time so they match.
fireflyinva is offline   Reply With Quote
Old 07-20-2004, 01:59 PM   #4
Nice! Thank you so much for all the detailed instructions and taking the time to write them all out!
I will definitely read over them and try to figure it out.
Rosie
It's Curtains! overlander63 Upholstery, Blinds, Walls & Interior Finishes 13 09-07-2003 11:08 AM
Factory Curtains sibyrnes Upholstery, Blinds, Walls & Interior Finishes 1 08-12-2003 03:10 PM
Curtain Pattern for '62 Bambi Marshall44 Upholstery, Blinds, Walls & Interior Finishes 15 03-17-2003 07:03 PM
Coloring original curtains in A/S? Hans Upholstery, Blinds, Walls & Interior Finishes 4 01-20-2003 02:49 PM
Interior curtains - Can you dye them? airstream97 Upholstery, Blinds, Walls & Interior Finishes 8 01-09-2003 01:34 PM
