Old 10-12-2010, 12:06 PM   #1
Silverslug75's Avatar
1973 31' Sovereign
Vashon , Washington
Need ideas Floor moulding
We just finished putting in new bamboo flooring and refinished the walls with honey gold veneer plywood. Super gorgeous! Now we need to put in floor moulding for the transition between the two. Is there anything classier than cheap vinyl cove moulding? We'd like something to fit with the real wood look we have going here, but it has to be thick enough at the bottom to cover the 1/8 to 1/2 inch gaps along the wall.
Silverslug75 is offline   Reply With Quote
Old 10-12-2010, 06:08 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
Why not just have some nice custom molding made? A lumber yard (not a big box) that specializes in supplying contractors will have a source for straight and curved moldings. You'll need to make templates for the curves. Or . . .
Just use a bendable non-wood product. There's a few on the market. I think Outwater has some too.
Flexible Moulding Concepts
Gary
Old 10-12-2010, 06:40 PM   #3
bonham , Texas
bamboo flooring sounds awesome
fst64_v8pwr is offline   Reply With Quote
Old 10-12-2010, 07:26 PM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
I am getting ready to put natural bamboo laminate in our "78" Ambassador. My questions as well. I do recall someone in the forums using a braided rope to cover the gap between the floor and the wall. It actually looked quite good. I don't think I would have thought of that...so maybe a type of round flexible material could be used. Do you have pictures of your new floor? Did you run it lengthwise or sideways...under your galley/bunks or around them. Thanks!
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 10-12-2010, 07:37 PM   #5
MDSilverado's Avatar
1977 31' Sovereign
Severna Park , Maryland
Originally Posted by Silverslug75 View Post
Super gorgeous!
Would love to see pictures!!!
MDSilverado is offline   Reply With Quote
Old 10-12-2010, 08:20 PM   #6
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Actually moulding is quite easy to make if you have a router and a router table. Pick out a bit you like, make a jig, make your own. Black walnut works easily and would be beautiful with the blonde bamboo. How about teak? A nice medium dark brown that goes well with blonde. You may need to make a trip to the local library to get a how-to book.
mhilley is offline   Reply With Quote
Old 10-12-2010, 11:41 PM   #7
1973 31' Sovereign
Vashon , Washington
No pictures yet. We ran it lengthwise. The whole AS has been gutted of everything so not any obstacles to work around.
Old 10-13-2010, 05:14 AM   #8
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Would love to see pictures. Almost ready to do my floor.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 10-13-2010, 08:05 AM   #9
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
M-D: Aluminum Cove Moulding - A747*
Old 10-13-2010, 10:35 AM   #10
mhilley's Avatar
2000 23' Safari
One other thing occured to me about making moulding. You can take a medium size steel flat head wood screw and screw it into the middle a small block of scrap wood. Leave the head about 1/2" (or whatever) out and use it by hand as a moulding plane. Just pull the block of scrap wood down the top edge of your moulding with the wood screw head slot at a 90 degree angle to the face of your moulding. The screw will cut a nice grove in the wood which you can easily hand sand. You can adjust the grove by screwing the wood screw in or out. It makes a very delicate shoe moulding that would look really nice in an A/S. If you are interested I will draw a sketch. I know the directions are rather hard to decypher.
Old 10-13-2010, 11:03 AM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Interesting idea from a couple of years ago, rope.
Vaughan
Remodeling Floor Plan Ideas Roskarin General Interior Topics 8 11-13-2011 07:05 AM
New Armstrong floor, just needs moulding magna1111 Floor Finishes 2 05-29-2008 09:16 PM
T Moulding howardlw Cabinets, Counter Tops & Furnishings 2 11-24-2007 08:00 PM
Ideas for replacing flooring for Minuet with aluminum composite floor pattyo Repairing/Replacing Floor &/or Frame 6 06-24-2006 08:56 PM
Ideas to change the floor plan / interieur of a 1979 Safari Hans General Interior Topics 0 12-23-2002 10:58 AM
