Old 08-06-2011, 08:54 AM   #1
Davis's Avatar
1996 34' Excella
Americus , Georgia
Need help with Interior End Caps
Hi , Both of my interior endcaps are cracking around the corners of the cabinets. The rear being the worst as it appears to be load bearing but I don`t have anything in them although the breaker box is in one side but it is fastened to the wall. The weight of the wooden doors could be causing the cracks but I am not sure.Also the area just above the cabinet doors in the rear seems to be seperating on top possibly heat related. Any one else experiencing this ? And what would be the best solution ?
Name:	Aug 2011 043.jpg
ID:	136872   Click image for larger version
Name:	Aug 2011 044.jpg
Name:	Aug 2011 048.jpg
1991 Airstream Excella 1000 34ft (SOLD)
1994 Chevrolet Crew Cab dually 2WD 6.5td
2005 Chevrolet Suburban LT 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
Davis is offline   Reply With Quote
Old 08-06-2011, 10:45 AM   #2
Davis's Avatar
1996 34' Excella
Americus , Georgia
Any ideas
AIR # 5131
Old 08-06-2011, 11:15 AM   #3
1977 Argosy 24
Milltown , Wisconsin
My best guess is your running gear is un balanced and the vibration is causing the cracks. Do you have any loose rivets on the inside (black circles around the rivets), or rivets that have fallen out?
ventport is offline   Reply With Quote
Old 08-06-2011, 12:30 PM   #4
Davis's Avatar
1996 34' Excella
Americus , Georgia
No rivets are missing. I replaced the tires,and shocks 2 yrs ago and they probably have less than 1000 miles on them.
AIR # 5131
Old 08-06-2011, 01:10 PM   #5
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Davis, those cracks seem to be common to many. Probably some age, vibrations, terrible roads, just one of those AS things. Try drilling a small hole, maybe 1/8'', at the end of the crack. May at least stop it. John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 08-06-2011, 06:19 PM   #6
Davis's Avatar
1996 34' Excella
Americus , Georgia
What about the last picture with the long gap beside the cabinet door, it seems loose there. Do you think I could put a bead of liquid nails there so it wont keep pulling apart ?
AIR # 5131
Old 08-07-2011, 08:09 AM   #7
sandlapper's Avatar
1993 34' Excella
Davis, inside the cabinet, at the crack, should be a plywood partition that is the end of the cabinet. Removing it should allow access to the back of the crack. Might apply a fiber glass "patch" over the length of the crack, on the inside. Kits are available auto parts stores & home centers. This should stabilize the crack. Then the outside cosmetics might be done with 5 minute epoxy, then color in with paint & artist brush once dry. Fiberglass & epoxy are handy stuff to have around. Practice first. john
John
Region 3 , 1st VP
Are you kind?
Old 08-07-2011, 07:17 PM   #8
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks . That sounds like a plan. And maybe I can figure out if extra support can be added as well inside the endcap to the alum. wall.
AIR # 5131
Old 09-08-2011, 06:46 PM   #9
Find some pieces of ABS, preferably white, a quart of MEK solvent, a metal 1 quart paint tin with tight lid and some fiberglass cloth.
Put a handfull of the ABS pieces in the Tin, and pour in a small amout of MEK. Seal the lid and leave for a few hours.
The MEK will melt the ABS, and form a paste. Adjust the amount of ABS or MEK to get a good consistancy.
Put a layer of Scotch tape on the visible side of the crack, and brush or squeeze the paste into the crack from behind.
The MEK in the paste will melt and fuse the 2 sides of the crack, and fill the void. Leave it to set, which may take several hours.
When it is hard, you can brush another coat of the paste on for strength, or even back it with Fiberglass.
Here is a spare wheel cover I repaired using the same method.
Here is how the MEK/ABS Paste looks.
Road worn corner..
Rebuilt..
Old 09-08-2011, 06:51 PM   #10
Then I taped it over to hold the corner..
Later I reinforced a cracked corner with the Paste and Fiberglass.
Forgot to take a pic when it was all wetted out and trimmed, but its strong now!
Old 03-07-2012, 11:27 PM   #11
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I have several cracks in both end caps.
When I was going through Harbor Freight today, I saw a kit to weld plastic - so I bought it. There are three types of welding rods depending on what type of plastic you are going to weld. What type of plastic is used for the interior end caps?
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 04-06-2012, 06:25 PM   #12
MaryContrary's Avatar
1984 31' Airstream310
on the road , CA and OR this summer!
Images: 41
Thumbs up thanks again Keyair
im ready to start my abs plastic fix on my tyre cover as well and stumbled across your pics...thanks a billion Keyair, you make it look so easy
i'm guessing the interior endcaps are very similar to fix.....i'm ripping the rear one out this weekend
1984 310 Limited Motorhome
my AS Moho blog
for the love of all vehicles round and shiny
MaryContrary is offline   Reply With Quote
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
Hub caps for standard 14.5" rim Jephellis Wheels, Hubs & Bearings 3 07-31-2011 05:16 PM
Neeed Help, caps for wall moparjohn Upholstery, Blinds, Walls & Interior Finishes 2 07-25-2011 10:20 PM
13 piece end caps Dan G Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 06-02-2011 01:42 PM
End caps - vinyl or what - how to clean kellywood General Interior Topics 10 03-18-2011 08:41 PM
