Old 11-08-2009, 09:06 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Need 70's Bronze Metal Trim
Don't try this at home folks. Have a (lousy) carpenter work on your Airstream trim with a hacksaw. So I'm looking for about a 6' strip of the Bronze corner edging to do this right. Haven't found anything that matcher from the new sources so perhaps someone out there who has gutted one has this.
What happened is I decided to reshape the curve to make the trailer a little more open when we replaced the panel. The rest was up to the carpenter who came up with a creative fix HELP!
RichHog is offline   Reply With Quote
Old 11-08-2009, 09:38 PM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
This is for... overhead storage end-piece?
Old 11-08-2009, 11:01 PM   #3
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Bronze Metal Trim on 72 TradeWind
Yes it's the piece next to the door. Here's a picture of the lower section above the fridge. We replaced the end panel and recut it to open up the end so a TV would be easier to see and to open the room some but kept the curves all the same.
Old 11-10-2009, 06:17 PM   #4
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I'm gutting a '74 Tradewind. Can you post photos of trim from front/top & end? What length do you need?
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 11-10-2009, 07:42 PM   #5
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Metal Trim?
I need about 6' of the trim for the endcap. The original Tradewind opening was closer to the front of the fridge. We cut it back to open it up the area to see the tv. We kept the curves the same but we need about 8" more than the original section.Here's the after and before pics.
Thanks!
Old 11-10-2009, 08:05 PM   #6
3 Dog Nite's Avatar
I'm still not sure which peice you need. All photos show trim from side. How thick is trim 1/4" or 1"? MyTT didn't have a solid wall there.
Ricky
Old 11-10-2009, 09:28 PM   #7
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Metal Trim?
The inside dimension is 1/4". On my trailer there is this rim on the end piece and on the opposite corner from the storage bin ceiling about 18" long. Didn't see the same trim anywhere else. Photo from opposite side above fridge
Old 11-11-2009, 07:15 AM   #8
Wabbiteer's Avatar
1972 29' Ambassador
I think there is a couple of smaller pieces of 1/4" edging without a home here.... No promises but I'll check my looted aluminum locker and post back a little later, neither of my trailers have that exact panel - but without dies and massive hydraulics there is no bending of it - someone good with a TIG welder might make it look seamless but you'd lose the anodize color & finish.
Old 11-11-2009, 05:22 PM   #9
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I didn't know that my little modification would bring such challenges. Yes bending it may be the hard thing, may have to wind up with some sort of plastic edging. Anything should be better than the hack saw marks on the cut sections on the current panel
Old 11-21-2009, 10:08 PM   #10
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Ideas to replace Bronze Metal Trim on 72 TradeWind
Anybody know of an alternative to the edge trim? Plastic? Saw a platinum trim at Ace but it seems that the tools to bend the curves to fit the wood are not a common thing. So I'm looking for alternatives?
Old 11-22-2009, 08:57 AM   #11
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Harbor Freight sells metal stretchers that might work to fit the metal edging to the curves, if you can find new metal edging.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Chris
Old 11-22-2009, 10:24 PM   #12
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
metal Trim
Thanks for the info. But for $199 it's a little pricey for a one time use. Plus whenever I do find the right metal I won't have any extra to practice with. It makes me want to re-think the whole thing. Of course I should have thought about that before cutting it up.
Old 11-23-2009, 09:45 AM   #13
Ottawa , ON
If you find a piece of the trim, it should be fairly easy to find a welder/fabricator to bend it for you...
Old 11-23-2009, 10:35 AM   #14
Kevin245's Avatar
Using a shrinker/stretcher is the only true way I know of to accomplish the bending and make it look original. Short of finding salavged parts somewhere I would try one of the following:
A. Find a local architectural or ornamental iron shop and see what they can do to replicate the curvature using your edge material. They typically have the tools (shrinker/strecher, bender, scroll, and english wheel, etc.) to form and bend metals into unique shapes.
B. Use a hacksaw to cut reliefs for your radii. This will not be aesthetically pleasing for "Outer" curves.
C. Look for a flexible edge material such as vinyl, rubber, or plastic that will form to the curvatures you need.
Good Luck,
Kevin
Eleanor Roosevelt
Bronze Metal Trim in 72 Tradewind RichHog Upholstery, Blinds, Walls & Interior Finishes 8 09-24-2009 07:45 AM
Bronze Edge Metal Trim 72 Tradewind RichHog General Interior Topics 8 09-23-2009 05:35 PM
70's era Metal Ceiling Specs and R & R (Remove & Replace) Facts Distantdrummer General Interior Topics 3 06-22-2008 03:04 PM
70's veneer and bathroom trim davidz71 Cabinets, Counter Tops & Furnishings 4 03-26-2004 07:58 AM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
