Old 05-27-2004, 10:28 PM   #1
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Name that finish!
I will be making repairs to some woodwork, replacing some missing panels, etc, and so I am wondering what this finish is. Has anyone else had to match this type of finish? Any tips? I think it is what I've seen refered to as pickled. This is on Bambi.
Stephanie
Old 05-27-2004, 11:07 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Although our finish isn't the "light pickled finish" like yours, (ours is a bit darker, but still "pickled") I ran into the same problem. Unfortunately it's nearly impossible to match!
Couple of reasons...first the EPA regulations have changed the composition of most lacquers, paints & finishes these days, compared to the 60's. So the chemical composition is not the same...
Secondly, even if you could match it aesthetically today...as it ages it will change whereas the 40+ year old finish has already aged - if it matches now, it probably won't in a couple of years. There is no way to know how it's going to age...is environmental. Even if you had a can of the exact same stuff...the 40+ years of aging vs newly applied would make a difference.
I ended up layering several different stains & tints to acheive a pretty close match, but I know it doesn't quite match and it may get worse over time. Short of refinishing all the cabinets, there's not a sure fire way of getting them all match.
Shari
Old 05-27-2004, 11:47 PM   #3
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
It's tempting to just rebuild, since it's such a small cabinet and the original one is riddled with screw holes from the many fine accessories which have been attached to it over the past 42 years, like so...
Stephanie
Old 05-27-2004, 11:55 PM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Talking I could...
You know?>,
That's a picture you just can't help but love~!!
I think you may have something valuable there...lmao
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
mirror finish what next? kooblekidz Cleaning, Stripping & Polishing 10 04-13-2009 07:24 PM
exterior finish durability vs. model year Kirby Stone Exterior Restoration Forum 16 08-08-2003 09:34 AM
exterior finish Roland Clearcoat, Exterior Paint & Trim 2 06-24-2003 01:04 PM
Very rough finish lenny Cleaning, Stripping & Polishing 9 11-11-2002 05:42 PM
Fixing a scratch on a brushed finish? acwdgw Cleaning, Stripping & Polishing 3 10-22-2002 01:27 PM
