Old 03-19-2013, 07:00 AM   #57
Kdawn's Avatar
1965 20' Globetrotter
Flin Flon , Manitoba
Just hoping to cash in on the gaucho knowledge.. Wigwag..do you have the dimensions of the small curved gaucho cushions.?.. The third one. I'm missing it in my 65 globetrotter !
i was mostly needing its widest part. I have been trying to get new foam cut but can't decide how wide that back cushion was meant to be. Thanks for bring this up again!! Thanks so much for any info!
Kdawn is offline   Reply With Quote
Old 03-19-2013, 08:38 AM   #58
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Try this link...
Originally Posted by wigwag View Post
Thanks, MaxAB. If you could direct me to your post, I'll have a look. I wonder if it's under Doors. Duh.
Wig:
Try going to this link...
http://www.airforums.com/forums/f164...ent-99692.html
My lockset is a Keeler - not a Bargman. There's a lot of difference. I believe the replacement lockset that VTS sells will replace the Keeler - not sure if it will also work to replace the Bargmans. Check with VTS if you have any questions.
I've got the replacement kit stowed in my AS should something happen to my repair job while we're on the road... Don't want to be stuck while not being able to secure the main door!
Good luck, amigo...
Art
MaxAB is offline   Reply With Quote
Old 03-21-2013, 03:48 PM   #59
1964 26' Overlander
Toronto , Ontario
Oh, Kdawn. I wish I did. Would really like to order some foam but I have no idea how much to get. Wish the OP would tell us!
wigwag is offline   Reply With Quote
Old 03-21-2013, 05:29 PM   #60
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
As I recall the curved cushion is the same width and length as the other narrow cushion you should have. Here is the pic of the pieces that I made for my previous trailer
http://www.airforums.com/forums/f116...tml#post136097
Post #25 if it doesn't go to it directly. I was looking for my templates. They have to be here somewhere...I never throw out anything.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 03-22-2013, 06:21 AM   #61
Kdawn's Avatar
Thanks for the link! I'm surprised at how big the curved cushion is... I guess I can just make a template from the empty space when I pull the gaucho out? Thanks for your help
Old 03-22-2013, 06:38 AM   #62
eljay's Avatar
1968 24' Tradewind
Yes, that would work. I used brown craft paper to trace the dimensions of the curved piece from the original. If I didn't have it I would have laid the other two foam pieces in place with the craft paper beneath them (being sure the paper was true and square to the sides and front of the trailer) and then cut or traced the template. Still looking for the templates I made. I'll probably find them when you post you are finished!
Eljay
Old 03-22-2013, 08:42 AM   #63
Tabasco's Avatar
1964 24' Tradewind
Stillwater , Oklahoma
Hi guys, I found my receipt from when I ordered new foam for my gaucho and twin bunks. I had the original couch that they used as a template, although it was pretty deteriorated.
Twin bunks: 33" wide x 74" long - they are just 6 inches skinnier than a standard twin size mattress, FYI. I went with a medium density foam that was 5" thick, they are comfy!
Gaucho:
Seat: 21" wide x 86" long x 5" thick (if my memory serves me right this was a little bit too long and I had to trim it a few inches, so 86" may have been a typo, sorry!)
Backrest: 15" wide x 76" long x 5 " thick
Hidden piece: 12" wide x 76" long x 5" thick
Now, this obviously doesn't take into account the curves and angles for the backrest and the hidden piece since they rest up against the curved walls of the trailer, but the foam is really easy to trim using an electric knife to get it perfect. Just like carving a turkey.
Good Luck!
Tabasco is offline   Reply With Quote
Old 03-23-2013, 03:26 AM   #64
1964 26' Overlander
Toronto , Ontario
Thanks loads for this! I can finally order my foam!!! Just to make things more complicated, Tabasco, do you know the lengths and widths of your beds? You have twins, right?
Thanks again.
Old 03-23-2013, 08:32 AM   #65
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
ELECTRIC CARVING KNIFE: They work great on memory foam mattresses! We installed a queen bed (Left-to-Right) with headboard along street side in aft bedroom. The electric knife was great to "carve" the foam to fit the curved wall!
Art
Old 03-23-2013, 08:48 AM   #66
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Now I know that with the gaucho slides you can lengthen them by decreasing their overlap, potentially making the bed much bigger. I have also heard that you can decrease the cushions from three to two. Has anyone done this...more importantly do you have photos of this!! Sorry if I have hijacked this thread but is is gaucho related!! You may want to consider this before ordering the foam!
http://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
accordion door alternative arodriguez60 Upholstery, Blinds, Walls & Interior Finishes 13 01-26-2010 07:29 AM
I need help with making Gaucho cushions, and Curtains netlace Upholstery, Blinds, Walls & Interior Finishes 10 09-04-2008 09:19 PM
Anyone replace the accordion door? Mackhopp 2002 - 2005 International 3 05-23-2007 01:10 PM
Bath Accordion Door CarlGeo Land Yacht/Legacy Motorhomes 3 04-17-2007 02:29 PM
Pocket Door vs. Accordion (folding) Door A/S Interior pap Cabinets, Counter Tops & Furnishings 12 03-10-2005 04:40 PM
