Old 08-31-2014, 06:59 AM   #1
2006 25' Safari
Ottawa , Ontario
musty carpet odour from leak
Our trailer had a leak which caused the carpet in an under-the-bed compartment to become musty. Any suggestions to get rid of the odour?
anniem is offline   Reply With Quote
Old 08-31-2014, 07:19 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, Temporary fix-Fabreeze. Long term fix may require pulling the carpet out. You may have mold and mildew growing in and underneath the carpet.
MICHAEL
Old 08-31-2014, 09:20 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I would definitely pull up a corner of the carpet to see what's going on underneath. This should not be a big deal since you say this is under the bed. You didn't specify the period of time that you think the leak existed. If it was a "one time thing" then I would not be too concerned, but it has been on going for awhile, you may have some issues with the wood subfloor. Best to know sooner rather than later!
Also, make sure you resolve the leak problem! No point in fixing the carpet and/or floor if the leak is still there.
Bob Martel
WBCCI# 5766
Old 08-31-2014, 09:33 AM   #4
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
I had a similar problem with an original mattress that came with our gauchos. It smelled awfully mildewy and musty. I narrowed it down to the fabric, not the foam. I tried Febreeze and vinegar to no avail. Last night I poured half a gallon of cheap vodka in a spray bottle and saturated the upholstery which is a tip I had seen on Pinterest. This morning I couldn't smell a thing. Musty or alcohol! Maybe this will work for you...
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Paddledipper is offline   Reply With Quote
Old 09-01-2014, 07:07 AM   #5
2006 25' Safari
Ottawa , Ontario
musty
Thanks, I'll try it
Old 09-01-2014, 07:34 AM   #6
dznf0g's Avatar
Oswego , Illinois
I cut the carpet out from under the under-bed storage. Why have carpet:
1) where dirty camping gear is
2) which is extra unnecessary weight
3) which traps water under it (and it is inevitable)
I replaced it with removable lightweight rubber flooring from HD. No odor, easily pulled up for cleaning and drying and probably 25 - 30#s lighter.
-Rich-
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 20 12-08-2015 12:18 AM
Musty odor: water damage? Ssmookler General Repair Forum 9 08-17-2014 08:41 PM
Mildew and musty odor gamakai Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-27-2012 02:05 PM
Water tank odour Dan S All Argosy Trailers 3 08-27-2012 08:47 PM
Old Musty Smell rebelstand General Interior Topics 29 07-08-2011 04:51 PM
