Old 05-28-2015, 07:27 PM   #1
Eugene , Oregon
mold damage to dinette cushion
One of our dinette cushions developed mold after our 2011 bambi got wet on the inside and sat for months. I am wondering what my options are for replacing vs cleaning the foam and upholstery. Thoughts?
wisaac42 is offline   Reply With Quote
Old 05-28-2015, 07:51 PM   #2
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
We are in the process of bringing an AS that was in a storage facility fire back to life. Our cushions were stained from fire suppression materials as well as from mold and mildew from water that seeped into melted fantastic fans and the melted skylight.
What I did: Took the cushions out and exposed to sunlight and heat. Then vacuumed up the debris and spores. Next, I sprayed them with vinegar, more sun exposure. Then, sprayed them with fabric upholstery cleaner, scrubbed the bad spots, used the vacuum brush the remove dried matter. This removed all the stains and made the fabric look pretty darned good except for the regions exposed to the fire suppression fluid, which unfortunately had a bleach like effect leaving slightly lighter spots with a reddened halo. Since you do not have that to deal with, you should have better luck in improving the look. If the mildew and mold were there for very long, the actual fabric fibers, if natural fiber, may be weakened and eventually wear through quicker than the rest of the upholstery.
I considered purchasing new, which is about $2.5K for a 25 ft dinette lounge. However, that is a chunk of money that I am hesitant to spend, as these now look so good.
Good luck!
Susan
duncans is offline   Reply With Quote
Old 05-28-2015, 08:02 PM   #3
Vintage Kin
Fort Worth , Texas
Check with ServPro or someone who does flood/fire remediation.
Replaced Dinette Seat Cushion Foam in 2014 23D interstateflyer 2011 - 2015 International 3 03-01-2015 12:55 PM
Dinette Modification to couch/dinette wmcmi_528 2002 - 2005 International 8 10-22-2014 08:27 AM
dinette cushion covers dutchess2035 Land Yacht/Legacy Motorhomes 5 01-12-2014 05:15 PM
Dinette cushion replacement covers 2004 Bambi CCD leejirik Upholstery, Blinds, Walls & Interior Finishes 0 08-17-2013 02:03 PM
Cushion anchor for seat-back cushion tomlong10 Upholstery, Blinds, Walls & Interior Finishes 1 01-13-2008 09:26 PM
