Old 03-10-2006, 02:17 PM   #15
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by azflycaster
BTW, the pump for the bed and the controls, do they run on 110 volts or do they have a 12 Volt model?
110 volt only. This really was designed for home use. If you start looking be sure you only look at the Aerobed Topper. Not the regular Aerobed which is a bed in itself.
If I were boondocking I would make sure that the beds were inflated to maximum pressure before I left. You can always bleed air out if necessary. Quite honestly one of the reasons I haven't moved faster on power for the pump is that we normally fill them to max pressure and don't make any adjustments. We've been out almost 10 days at a time and they don't seem to lose pressure in that time frame.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-10-2006, 03:25 PM   #16
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
The mattress in our 34' was the original Airstream RV-queen (read short) mattress that was nine years old and in not-very-good condition. My wife tore out the headboard and we bought a memory foam full-sized queen and installed it. We liked it so well, we moved our select-comfort style airbed into our guest room and bought a second memory foam queen for the house!
It's so nice not having to adjust to a different bed when we use the trailer.
Roger
Old 03-10-2006, 05:18 PM   #17
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I purchased the 2" memory foam topper with 5 lb. density and put it on our king size bed at home. My wife loves it. I am eyeing the same thing for the Sovereign and will probably order from Overstock.com like I did the first one.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-10-2006, 06:38 PM   #18
65glbtrotter's Avatar
1965 20' Globetrotter
Yakima , Washington
Images: 31
Our '65 still had the original foam and it was like old hard bread (hard but crumbles with use), we just had new cushions madewith a four inch premium base and two inches of memory foam, so nice we had to sleep in the trailer just to try them out. Wow waht a difference that makes, and they were only $600 for both gouchos.
Cory Harrington
http://65airstream.tripod.com/
Alumineyezed
AIR 7834 WBCCI 2105/VAC
65glbtrotter is offline   Reply With Quote
Old 03-10-2006, 10:43 PM   #19
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
I'm pondering this foam issue: With the dinnetes, or even the goucho, do the cushions breakdown from all the butt pressure... and become lumpy to sleep on? Does anyone carry along a topper to roll out over the cushions... in particular with the dinnete and the abundance of seams from the cushions pushed together?
sequoiacoast is offline   Reply With Quote
Old 02-23-2009, 07:29 PM   #20
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by myoung View Post
Dennis,
Perhaps our 2006 model has softer mattresses. What does that say about the pre-2006 models?
Firm but....comfortable. Old school..use a down quilt at times.
Love our twin layout.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-23-2009, 08:16 PM   #21
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Oddly enough, I sleep like a baby on the Airstream factory bed. I have a memory foam at home and like it, but don't sleep as well as I do in the Stream...go figure.
Old 02-23-2009, 09:53 PM   #22
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, same here; We have memory foam topper at home and we sleep better in the trailer. The factory mattress is pretty firm and the pillows are very soft, so we double up on the pillows.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-24-2009, 01:29 PM   #23
Other than my down topper I haven't changed from factory set-up. That way when the DW hop's over for a visit I can just thro it on the floor, she likes firm, better purchase I guess.
PFC
"Tahawus"
RLC
John Prine
Old 02-24-2009, 02:39 PM   #24
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
We had our cushion remade with new premium foam and fabric. We used such a high grade of foam that the cushions were too hard to sleep on. We now carry a 2" memory foam topper for when we make up the dinette and couch into beds. Sleeping is bearable now.
The only downer with this setup is storing the foam topper during the day. It usually gets wrapped and tossed in the shower. You folks with permanent trailer beds have it nice!
crispyboy is online now   Reply With Quote
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-05-2006 11:00 PM
foam cushion replacement mareinmn Upholstery, Blinds, Walls & Interior Finishes 1 03-11-2003 09:21 AM
Foggy Memory Ln. Rusty Bucket Our Community 1 12-29-2002 07:07 PM
Memory Lane--Avion, Boles-Aero, Spartan Manor Kistler Our Community 1 12-29-2002 07:02 PM
Twin rear beds DClark General Interior Topics 15 11-24-2002 08:49 PM
