Old 02-28-2010, 08:14 AM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Memory foam ??
Is memory foam good for bedding and cushions, and what would be a good density?.......thanks toastie
toastie is offline   Reply With Quote
Old 02-28-2010, 08:34 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
We bought a memory foam topper for the bed. It works well for that application. I also have a memory foam pillow. For seating I do not think it would work as well.
Old 02-28-2010, 08:37 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I have a 2" memory foam topper on my factory bed. It works wonders.
For cushions. We use it in Aircraft for long duration flight. ie, firefighting.
Michelle TAC MT-0
Sarah, Snowball
Old 02-28-2010, 08:59 AM   #4
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Someone said it freezes, does it? Their Airstream was not heated in the cold climate and when they went to lie down on the bed and they said it freezes.
I was thinking I wanted to add that to our beds until I read that. We do sometimes stop and use the beds on the road when the beds could be unheated or at least minimally heated from the furnace.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 02-28-2010, 09:00 AM   #5
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I use 3 inch memory foam for the beds in both of my trailers. I laminated it to a 4 inch high density foam base for a total of 7 inch thickness. If you used memory foam alone I think it would "bottom out" and would lack very much in comfort.
I also made a couple of removable cushions for my pickup seats using 2 inch memory foam. They do wonders reducing "Toyota butt" on long trips.
The memory foam can get quite hard when cold, but relaxes with body heat or ambient temperatures.
Sam
samb is offline   Reply With Quote
Old 02-28-2010, 09:01 AM   #6
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
We did 2+2 (2" polyurethane & 2" memory) memory foam pad (target brand) on our rear queen bed. Works fantastic... the OEM mattress was 'unsleepable' by itself- now its more comfortable than our home simmons... best bang-for-the-buck upgrade to the RV to date!
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 02-28-2010, 09:05 AM   #7
toastie's Avatar
1955 22' Safari
For the bedding we are looking at 8" memory foam, we have 2 fixed beds that we will have to contour the foam to the radius of the trailer........toastie
Old 02-28-2010, 09:16 AM   #8
LisaP's Avatar
2008 25' Safari SS SE
Colleyville , Texas
Toastie,
I would try that 8" first before you fit it to your trailer. I agree with finalcutjoe. Memory foam alone you sink down too low to turn comfortably. I would prefer the 2" topper. I tried the memory foam mattress and did not like it. Just try it first.
LisaP is offline   Reply With Quote
Old 02-28-2010, 09:30 AM   #9
toastie's Avatar
1955 22' Safari
Originally Posted by LisaP View Post
Toastie,
Thanks very much, this type of info is very helpful, below is the detail's
of the bedding that we are looking at
2-inch premium layer of 3-pound memory foam
6-inch base layer of 2-pound foam
Old 02-28-2010, 09:32 AM   #10
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
there is a "high quality" (poly, I think) at foamdistributors.com that I plan on using for my cushions/bed upgrade... I found memory foam too saggy for my troublesome lumbar, although I do think they're making it in firmer versions now.... just beware if you have a history of back trouble..
fotochop is offline   Reply With Quote
Old 02-28-2010, 09:41 AM   #11
mouth012006's Avatar
1974 Argosy 24
Science Hill , Kentucky
Images: 51
that is our base foam....then we put a 2" memory foam topper on top.....love our mattress
Kevin & Monique
New to A/S---Not to Honey Do's
Sweetie (lab) Snickers (lab) Blackie(lab)
Dotz(daschund) CB (daschund) Oh and 3 kids!!!
TAC# KY-3
mouth012006 is offline   Reply With Quote
Old 02-28-2010, 09:44 AM   #12
toastie's Avatar
1955 22' Safari
What is the thickness show in the picture?........thanks
Old 02-28-2010, 11:05 AM   #13
2010 25' FB Flying Cloud
Davenport , Iowa
Iretired from doing custom wheelchair seating. I used a combination of sunmate foam and pudge foam. This worked great for preventing ulcers on your bottom. The sunmate foam came in different densities. There was a pink, blue and green. A piece of the blue in 4 inch became rock hard when cold. Look at ther sunmate web and contact the company.
With the pudge, one could put a large ring of keys down and challange a not knowing person to see if they could feel them--NOT
mike
Airtandem is online now   Reply With Quote
Old 02-28-2010, 11:42 AM   #14
r carl's Avatar
Lin , Ne
Ive always thought a memory foam matress would be great for a motorhome, you can take a nap while traveling and not roll out of the bed while going around a corner.
Replacing rear twin beds with memory foam mcair Upholstery, Blinds, Walls & Interior Finishes 12 06-10-2009 10:22 AM
Memory foam for our new AS myoung Upholstery, Blinds, Walls & Interior Finishes 23 02-24-2009 02:39 PM
newbie sofa memory foam query Hhthorny General Interior Topics 3 06-09-2008 05:29 AM
If my memory serves me? Mrcrowley Cleaning, Stripping & Polishing 3 05-28-2007 03:14 PM
Cozy Tyme 3" Thick Memory Foam campcollector Our Community 0 05-17-2005 07:28 PM
