Old 03-07-2015, 07:19 PM   #1
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Matching interior "wood" paneling color
We recently installed a microwave in our 2006 Bambi 19. I used clear alder for the microwave frame and now I'd like to finish it. A friend recommended a clear sealer, but the finish is too red. See the attached pic. Has anyone found a good match for this common AS finish. Thanks in advance for any advice.
George
Name:	wood finishes.jpg
ghatfield is offline   Reply With Quote
Old 03-07-2015, 10:52 PM   #2
2007 22' International CCD
Try waterbased clear polyurethane. I use Minwax Polycrylic. Satin has less shine and drys totally clear. It goes on 'milky' but drys very clear.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 03-19-2015, 02:28 PM   #3
ghatfield's Avatar
2006 19' Safari SE
Pickled Oak Minwax is the product to use
I tried several different finishes including the Minwax Polycrylic. All produced similar results.... a nice light brown finish. I picked the one that looked the closest to the paneling color (a wipe on polyurethane) and tried it, but when I installed the microwave frame with that finish, it was just too brown (see attached).
So I tried some Minwax Pickled Oak finish and applied two thin coats with a cloth on top of the polyurethane. I let the finish dry about 12 hours between coats. The resulting finish was quite close (see attached). Not a perfect match, but close enough, at least for me.
ID:	234554   Click image for larger version
Name:	polyurethane plus minwax pickled oak.jpg
Old 03-27-2015, 02:06 PM   #4
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Hi, I had the same experience recently trying to match my ash in my '69 Safari.
From what I can see in the picture your raw woods colour is pretty darn close to what you need and that was the same issue I had, as soon as I added a finish the colouring dramatically changed, I went through umpteen different finishes and even pickling in an attempt to get it right. In the end the one that worked for me was Minwax brushable laquer. It didn't change the colour of the wood from the original at all. I used a cheap foam brush and brushed it on fast. It self levels to a point but it quickly kicks over like an epoxy and leaves brush marks if you work too slowly.
After some research I found that a lacquer finish was what was used in my year anyway so I also used it to top coat some areas of the original cabinetry as well, again without affecting the original colour.
Minwax 1-qt. Gloss Clear Brushing Lacquer-15500 - The Home Depot
Good Luck
thesignlady is offline   Reply With Quote
Old 03-27-2015, 02:21 PM   #5
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Nice work, George. As an old woodwork manufacturer I applaud your method of trying various products for the best "blend" of color, figure, and sheen. The word "match" carries too much baggage in the world of woodworking. The best any of us can hope for is a great blend of the natural characteristics of real wood with existing work.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Wood Paneling: Recommend a good thread? Aktundra Upholstery, Blinds, Walls & Interior Finishes 13 11-26-2014 08:52 PM
Old Walnut paneling different color than new walnut paneling geodazed Upholstery, Blinds, Walls & Interior Finishes 11 06-06-2011 07:53 PM
Wood Paneling niftypkg General Interior Topics 5 03-03-2007 07:24 PM
renewing interior wood paneling mjmcwhorte Cabinets, Counter Tops & Furnishings 16 01-05-2006 11:05 PM
