Old 01-30-2009, 03:44 PM   #15
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
First A/S unlined. Classic lined...we vote lined.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-30-2009, 05:35 PM   #16
Buzzy4's Avatar
2007 25' Safari FB SE
Argyle , Texas
We've had one of each. We do a lot of boondocking and it is often quite dusty. Thought the fuzzy walls would start looking pretty nasty after a while even with frequent vacuuming. The aluminum walls are much easier to clean.
As for insulation, we find that here in Texas in the summer it takes a bit longer to cool the metal interior but, with a 15,000 btu AC it isn't much of a problem. We have also stayed in both types in weather that was in the teens and found little difference in the comfort. The walls are a bit cooler to the touch and perhaps we use a bit more propane keeping it warm, but we have never been cold.
For my purpose it is aluminum without question.
Buzzy4 is offline   Reply With Quote
Old 01-30-2009, 05:53 PM   #17
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up
Originally Posted by Foiled Again View Post
Fling your arm up over your head while sleeping in 28 degree weather - you'll wake up abruptly.
Wish Airstream had a happy medium - Wainscotting with fabric in the bedroom - and bare above. I suppose that with a minimum of effort I could use a quilted fabric to make my own, and even attach the with the removable 3M removable hook hanger thingies (double sided foam strips with adhesive on both sides - that you pull and stretch to release. Easy to clean too.
Paula
Crap - another project - and I don't even own vintage.
Paula
Paula,
Next time when I am down, I'll show you this wainscoting you wished for in my unit..It's pattern is rather simple to replica ..And, YES..It's nice to touch with barefoot year round~!!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 01-30-2009, 06:19 PM   #18
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Any metal surface will feel cooler than a cloth one, even if it is the same temp. I sometimes wonder if the belief the aluminum interiors are colder or warmer than the mouse fur ones is "conventional wisdom". Does one feel different because of a perception that is not objective? Has it been measured with a thermometer? Just curious since we're not going to sell ours with aluminum interior. If the windows are smaller (see Post #6) in the mouse fur units, that would probably make the biggest difference in temp.
We liked the aluminum interior—after all, isn't this about design and aluminum? We were concerned about the mouse fur (if you own one with mouse fur, you'll call it "lined") absorbing cooking odors plus keeping it clean. The aluminum looks really cool, especially when the lights reflect off it. Do not rub against the aluminum anytime, but especially in the winter, while naked—it will always feel cold. Maybe some people like rubbing against it, don't let me stop you.
So, like 28totow writes, it's a matter of taste. Make sure of what you like and then buy it.
Gene
Old 02-03-2009, 10:46 AM   #19
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I put this in our 1972
Soveriegn. The previous owners had drill holes for various items and the walls were stained so we went with putting this on the walls in the living area and in the twin bedroom area. It looks great and provides excellent insulating properties. When you install it make sure you use lots of spray adhesive. Oh yeah, the stuff is called Ozite Fabric aka hull liner.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Interior skin cookeville34 General Interior Topics 6 09-25-2006 03:19 PM
Interior Plans Chris Holt General Interior Topics 5 11-02-2005 01:23 PM
need interior help whistler Interior Restoration Forum 20 01-08-2005 07:14 PM
New Interior jjonesnc Upholstery, Blinds, Walls & Interior Finishes 2 09-07-2003 05:25 AM
Want A New Interior For Less Than $5.00? Inland RV Center, In Upholstery, Blinds, Walls & Interior Finishes 2 05-03-2002 10:35 AM
